Still Not Starting Right, Cry For Help!
#41
Posted 25 February 2015 - 12:28 PM
#42
Posted 25 February 2015 - 01:03 PM
#43
Posted 25 February 2015 - 01:04 PM
#44
Posted 25 February 2015 - 01:09 PM
#45
Posted 25 February 2015 - 01:10 PM
#46
Posted 25 February 2015 - 01:15 PM
#47
Posted 27 February 2015 - 10:04 AM
Fuel pressure gauge turned up.
Again this wasn't a bad start (possibly as it primed when I turned the key to disengage the steering lock so I could push it out the garage to film in the light)
Observations are:
It's very slow at building up pressure (but I've nothing to compare this to, can anyone that's measured there's say if its different or link to a vid)
Idle pressure is 3.4bar not 3.8 (but I don't expect a gauge that cost <£30 inc plenty of adaptors and postage to be super accurate)
pressure fluctuates when revving even without load (I'm guessing this is really not right, but again I've nothing to compare it to)
Basically I think this is telling me the pump is fooked, but I want to be certain. I don't want to spend >£100 on a pump and spend a day of my time to find out I've changed something there was no problem with and still have problematic starts!
#49
Posted 27 February 2015 - 10:10 AM
The pipes which are famous for being oh so easy to change, oh joy!
Still it would be cheaper!
#50
Posted 27 February 2015 - 10:37 AM
Observations are:
To save a click
#51
Posted 27 February 2015 - 12:37 PM
Lifting the pump housing just to check costs nothing.
(other then dremel time, and if you have an early generation clip system, the connectors may struggle back a bit before coming unloose.)
I would say rule of thumb is that the pump housing should go back in the tank and compress with almost no pressure needed.
if not, you are forcing something.
#52
Posted 28 February 2015 - 09:42 PM
I can very confidently say that is way, way to slow to build up pressure.
When I had Nicks pressure tester (which is identical to yours) it jumped up immediately turning the key on and even when starting almost instantly jumps up to 3.8
It seems once it's up to pressure it's ok and when you rev it raises as it should ok also.
Have you done any track days and found it running out of puff or it running lean on WOT when logging?
My guess would be leak, but I guess the pump is always a possibility.
Could you pull the whole pump and gubbins out and run it in a bucket and see if any of the pipes are leaking?
Edited by Bargi, 28 February 2015 - 09:49 PM.
#53
Posted 28 February 2015 - 09:55 PM
looking again, when you rev it doesn't even got over 3.8 which doesn't seem right
When I had my car on the dyno it went well over 4, but you are just revving without load so maybe it doesn't go up as much
#54
Posted 28 February 2015 - 10:20 PM
I'm an idiot, I took a video when I had the gauge, even with the obligatory heavy breathing!
Your pump only primes to 3 while mine reaches 4
Much slower to prime
Drops off much quicker
The dropping off quicker I think points to a leak.
Edited by Bargi, 28 February 2015 - 10:21 PM.
#55
Posted 28 February 2015 - 10:35 PM
#56
Posted 28 February 2015 - 11:30 PM
Cheers Bargi, exactly what I was afterI'm an idiot, I took a video when I had the gauge, even with the obligatory heavy breathing! clicky Your pump only primes to 3 while mine reaches 4 Much slower to prime Drops off much quicker The dropping off quicker I think points to a leak.
#57
Posted 28 February 2015 - 11:33 PM
Yeah I tried this some time ago, no difference it just throws the EML (something to do with the immobiliser, I guess it doesn't t like the ignition going on and off too many times without starting)Have you tried priming the car more than once before starting?
Done this as well, that's what the video is of.you can stick a pressure gauge on it to see what's happening.
Edited by Chris P Duck, 28 February 2015 - 11:36 PM.
#58
Posted 28 February 2015 - 11:37 PM
Edited by pete-r, 28 February 2015 - 11:38 PM.
#59
Posted 28 February 2015 - 11:42 PM
Edited by Chris P Duck, 28 February 2015 - 11:43 PM.
#60
Posted 01 March 2015 - 12:35 AM
That spring is not so strong, and can be done one side at a time with a bodkin or something.
