Oil Plate Spanner
#161
Posted 08 September 2015 - 06:55 PM
#162
Posted 09 September 2015 - 07:56 PM
#163
Posted 09 September 2015 - 08:07 PM
nice one
#164
Posted 09 September 2015 - 11:25 PM
#165
Posted 10 September 2015 - 12:07 PM
#166
Posted 10 September 2015 - 04:12 PM
#167
Posted 16 September 2015 - 09:32 AM
#168
Posted 16 September 2015 - 10:55 AM
#169
Posted 16 September 2015 - 02:50 PM
#170
Posted 20 September 2015 - 10:16 AM
#171
Posted 22 September 2015 - 11:41 AM
#172
Posted 23 September 2015 - 01:50 PM
#173
Posted 03 October 2015 - 08:04 AM
#174
Posted 03 October 2015 - 10:14 AM
Hi, can you confirm that this is the tool required to remove the top of the oil filter housing unit so the oil filter can be replaced. Thanks, Mike.
#175
Posted 03 October 2015 - 11:31 AM
#176
Posted 03 October 2015 - 01:10 PM
#177
Posted 22 November 2015 - 11:49 AM
#178
Posted 23 November 2015 - 09:07 AM
So just to get this straight in my head... (never done the filter on this stupid car)
This spanner lets you just take the cap off without undoing the sandwich plate? Meaning you don't need the seals?
#179
Posted 23 November 2015 - 10:01 AM
#180
Posted 23 November 2015 - 10:10 AM
The cap is removed with either a 32mm shallow socket or a 1/2 inch socket extension, it screws down into the adaptor tube. The adaptor tube locks the sandwich plate in place and it is this which requires Chippy's special internally toothed ring spanner to remove it from the block, or to separate it from the cap if the two have come out together when undoing the cap. The cap seals to the adaptor tube with an O ring. The sandwich plate has two seals, the upper between the collar of the adaptor tube and the sandwich plate and the lower between the sandwich plate and the rim of the filter pocket. These gaskets were originally very thin metal items, no longer available from VML, but graphite replacements are available from Mat Jackson. The tube tightens to 120Nm and the cap to 25Nm. Hope that helps!
