Posted 03 March 2015 - 11:02 PM
Posted 04 March 2015 - 07:54 AM
might be worth checking for any ECU codes
Posted 04 March 2015 - 08:08 AM
Posted 04 March 2015 - 08:21 AM
Posted 04 March 2015 - 08:59 AM
Posted 04 March 2015 - 09:02 AM
Is the rear boot wet under the carpet/foam?
Posted 04 March 2015 - 09:15 AM
Posted 04 March 2015 - 09:32 AM
Posted 04 March 2015 - 05:55 PM
Posted 04 March 2015 - 05:56 PM
Posted 04 March 2015 - 11:45 PM
Posted 05 March 2015 - 07:29 AM
Posted 05 March 2015 - 09:01 AM
Rear boot hidden behind black plastic box on left
That. Mine were soaking and shorting out/melting, hence the dry boot question.
Posted 08 March 2015 - 10:11 AM
Thank you again guys - Put the meter on and showing that the fuel pump relay has blown! Next problem is figuring out which one that is!
See photo - http://s1380.photobu...ail_share_media
Again it seems that someone has had this problem before - If anyone knows which of these will make my life a lot easier!
Posted 08 March 2015 - 10:13 AM
Edited by rhoran00, 08 March 2015 - 10:14 AM.
Posted 08 March 2015 - 10:24 AM
Thanks Rhoran
I've tried one of the relays front the front and it's still not working I am beginning to think that it's maybe the Lotus Start Inhibit Module!
Posted 08 March 2015 - 10:32 AM
I noticed yesterday mine is wet there... Any ideas where the water/moisture comes from?
Posted 19 March 2015 - 08:21 AM
Hi Alan
Did you ever get the car sorted?
Can you please send my full deposit back, you can pay me by cheque if you like, apparently you are good at writing cheques!
Posted 23 April 2015 - 05:27 AM
Also tagged with one or more of these keywords: not starting
General Discussion →
VX220 Discussion →
Tech2 Not Connecting To EcuStarted by Ebo100 , 31 May 2016 ![]() |
