Radiator Fan Switch On Temperature
Posted 21 March 2015 - 03:23 PM
Posted 21 March 2015 - 03:41 PM
Fans on the OEM cars come on at 108 if I recall correctly.
Possible to change this parameter with the Dutch ECU to something more reasonable.
Posted 22 March 2015 - 05:40 PM
Hi nightrider,
Good guide on here somewhere on how to fit a fan overide by earthing one of the cables that passes down the centre console. Useful when stuck in traffic on hot days to keep the temp down and ease your paranoia of a cooked engine.
Posted 22 March 2015 - 10:52 PM
Posted 23 March 2015 - 06:34 AM
Posted 12 April 2015 - 08:08 PM
Posted 12 April 2015 - 11:20 PM
Posted 13 April 2015 - 10:55 AM
106 on the NA.
and solder... bad boy
Posted 13 April 2015 - 02:38 PM
... and 106 shouldn't hurt it, should it? Mine will hit that on a hot day in traffic - the fans kick in and turn off again at 99 (I think). I certainly don't worry about it.
Posted 13 April 2015 - 02:44 PM
Absolutely. I twitched a little the first few times the temp hit 106, but there are never any issues. It's no K series is it?... and 106 shouldn't hurt it, should it? Mine will hit that on a hot day in traffic - the fans kick in and turn off again at 99 (I think). I certainly don't worry about it.
Posted 13 April 2015 - 06:04 PM
Posted 25 April 2015 - 11:00 PM
I hit 110 today in traffic for first time ever. I DID NOT hear a fan kick in.... time to investigate me thinks!?
Are the fans on a fused supply?
Posted 09 May 2015 - 09:08 PM
130 degree C is pretty hot Bargi, you should consider the fan override switch (easy mod) so you can pre-emptivly switch it on.
Edited by Nev, 09 May 2015 - 09:09 PM.
Posted 10 May 2015 - 07:36 AM
Posted 10 May 2015 - 08:09 AM
It does not go further then 130 bargi.
I destroyed my head gasket learning that.
Posted 10 May 2015 - 08:28 AM
Also tagged with one or more of these keywords: cooling fan, thermal switch, temperature
General Discussion →
VX220 Discussion →
Extra Water Temp SensorStarted by Hammy of hamhouse , 26 Jul 2013 ![]() |
