Supercharger Conversion
supercharger sc stage 2
53 replies to this topic
#41 alkvalseth
alkvalseth
  • 89 posts
Posted 06 May 2015 - 08:06 PM
Great, will read that! :)
#42 alkvalseth
alkvalseth
  • 89 posts
Posted 26 June 2015 - 10:48 PM
Hey guys! I need your help! Today I changed the downpipe (?) to one without a cat. Right after, I tried the car to listen to the sound, and about five seconds after I went off the gas, I heard a quite loud bang. Then, I ran on 3 cylinders. I don't know if the bang had anything to do with the loss of one cylinder or not. First I thought it was unburned fuel that ignited, and maybe it was, but anyway, now I have an issue. Any ideas what might be wrong?
Thanks
Andreas
#43 pete-r
pete-r
  • 2,771 posts
Posted 26 June 2015 - 11:16 PM
Have you removed the lambda sensor? If so have you turned it off in the ecu (assuming dutch software)? Not sure why it would drop a cylinder either way, Any error codes?
#44 alkvalseth
alkvalseth
  • 89 posts
Posted 26 June 2015 - 11:19 PM
I have both lambda sensors in place, but I haven't turned it off in the ECU yet. (Have got dutch). But I didn't get any error codes, and as you say, as far as I can see it shouldn't drop a cylinder..
#45 CHILL Gone DUTCH
Posted 27 June 2015 - 11:10 AM
Wonder if you did some damage when the coolant ran low ? Might me time for a compression test and have valves etc checked Good luck
#46 Bargi
Bargi
  • 4,483 posts
Posted 27 June 2015 - 11:39 AM
Maybe you've bumped something while changing the pipe. Check your spark plugs, reseat coil pack and check wires and plugs around the engine bay.
#47 alkvalseth
alkvalseth
  • 89 posts
Posted 27 June 2015 - 12:45 PM
Thanks for the advices guys, I think it might be the coil pack, but not sure. I have driven for quite some time since I had low coolant levels, but I going to do a compression test. Thanks for the tips!
#48 fezzasus
Posted 27 June 2015 - 12:52 PM
Unlikely to be the coil pack. It's wasted spark so one coil for two cylinders, you'd be running on two if it's a coil has failed.
Last conversion I did, the injector plugs weren't sitting properly and some material needed cutting away. I suggest you start there.
#49 alkvalseth
alkvalseth
  • 89 posts
Posted 27 June 2015 - 12:56 PM
Actually I forgot to say that it doesn't necessarily sound like it's running on three cylinders, it might as well be two. I saw that there was two coils in the coil pack: would misfunction of one of these cause an unbalanced engine?
#50 alkvalseth
alkvalseth
  • 89 posts
Posted 03 July 2015 - 01:25 PM
I have found the problem! My coil pack is broken! So should be an easy fix. But I only have access to a coil pack for a Z22YH. Is this going to work on a Z22SE? Would appreciate a quick answer, as I need to order now :)
Thanks
#51 The Batman
Posted 03 July 2015 - 03:09 PM
Nope won't work
#52 alkvalseth
alkvalseth
  • 89 posts
Posted 03 July 2015 - 03:22 PM
Thanks for the quick answer mate!
#53 OscMaz85
OscMaz85
  • 2 posts
Posted Yesterday, 02:30 AM
What did you grab power from to run the water pump? Did you use a relay + fuse?
I mounted mine to the old air box bracket:
#54 OscMaz85
OscMaz85
  • 2 posts
Posted Yesterday, 02:32 AM
I did the same as Captain - with a load of foam rubber to help isolate vibes..
Also tagged with one or more of these keywords: supercharger, sc, stage 2
