Posted 14 June 2015 - 07:49 AM
Posted 19 June 2015 - 06:18 PM
Posted 21 June 2015 - 10:43 PM
Posted 04 July 2015 - 01:59 AM
Posted 04 July 2015 - 07:04 AM
Posted 04 July 2015 - 08:26 AM
Posted 04 July 2015 - 08:35 AM
Run a oil temp gauge to the drain plug with a sender as they get very hot , If you are tracking race quality oil 75/90 syn5 type.
Posted 04 July 2015 - 08:51 AM
Posted 04 July 2015 - 09:12 AM
I run a Mocul oil cooler and 12v pump on a manual switch with temperature gauge, holding 1 litre extra oil. It works well keeping the oil temp down.
Posted 04 July 2015 - 09:17 AM
Posted 04 July 2015 - 09:22 AM
I was told to use the cooler from 70oC . Fitting was a pain , I had a bracket welded on to the left hds roll bar support.
Posted 04 July 2015 - 09:24 AM
Posted 04 July 2015 - 09:25 AM
Posted 12 July 2015 - 07:54 AM
Posted 08 April 2016 - 06:22 AM
Posted 08 April 2016 - 06:48 AM
WOW, that Spitfire tie rod looks beefy !
What size threaded ball joints does it use? M10 or M12 or even bigger ?!
Edited by Nev, 08 April 2016 - 06:49 AM.
Posted 08 April 2016 - 06:57 AM
Posted 08 April 2016 - 10:10 AM
Posted 08 April 2016 - 11:49 AM
Posted 08 April 2016 - 11:53 AM
Edited by squarepant5, 08 April 2016 - 11:53 AM.
