Pete's Project 'dingleberry'
115 replies to this topic
#81 Arno
Arno
  • 1,238 posts
Posted 13 October 2016 - 12:29 PM
I might buy an s2 cover and butcher it to fit.
Make sure it's a cover off of a Toyota powered Elise and not a Rover one.
The Rover powered Elise one has a more low-profile gear lever construction with all the cables attached at the bottom and won't fit over the VX 'high mount' cable style lever and also the handbrake lever is mounted a little differently.
Toyota version should have a good chance to fit over the gear mechanism in the VX though. May need some adjustment/tweaks but it should be fairly similarly sized.
#82 pete-r
pete-r
  • 2,771 posts
Posted 27 September 2017 - 09:31 PM
As all of my pics have fallen foul of the photobucket issue I'll have to repost some of the useful ones. Boo!
Meantime, hello Flickr!
#83 pete-r
pete-r
  • 2,771 posts
Posted 28 December 2017 - 12:11 PM
Started migrating to Flickr from photobucket so just put a few pics up of use that I've been asked questions on etc. Not reposting all of them I can't be arsed...
#84 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 28 December 2017 - 12:38 PM
Carbon dash panel looks smart Pete 👍
#85 pete-r
pete-r
  • 2,771 posts
Posted 28 December 2017 - 12:57 PM
Thanks Chris, I couldn't hear the radio anymore so figured I'd ditch it and put a tray in, then started thinking about how I'd like some USB charging points up front for the sat nav, one thing led to another and this was the result. If you want one I have another 3 long enough to do both sides of the dash ;)
#86 VegyBS
VegyBS
  • 183 posts
Posted 29 December 2017 - 02:54 PM
What wheels are those Pete? Also a fan of that simplistic dash.
#87 pete-r
pete-r
  • 2,771 posts
Posted 29 December 2017 - 03:06 PM
Hi, they are Lotus wheels from the Exige 260 cup. Saves 18kg from stock.
Edited by pete-r, 29 December 2017 - 03:10 PM.
#88 pete-r
pete-r
  • 2,771 posts
Posted 02 February 2018 - 06:18 PM
Bonnet mod done today on a spare.
No more cable/lever issues!
Need to wrap it next...
#89 Danny Scarbro
Danny Scarbro
  • 245 posts
  • Interests:Track days!
Posted 07 February 2018 - 11:18 AM
Great job on the bonnet Pete. Looks great.
#90 pete-r
pete-r
  • 2,771 posts
Posted 07 February 2018 - 12:06 PM
Thanks Danny, your pics definitely helped. Measure ten times cut once was my motto. Got a spare boot incoming so I'll be doing the same at the back soon. It seems much more secure then the OEM latch.
#91 pete-r
pete-r
  • 2,771 posts
Posted 07 February 2018 - 05:42 PM
Latched it using two bits of carbon through the alarm "bonnet open" switch hole. There's a piece underneath inside the folded metal so it can't move around. Fits sweet.
#92 Nev
Posted 08 February 2018 - 07:35 AM
I think you might find the trailing corners of the bonnet will still flap like mad (which I used to find a distraction). I have a latch at each corner and even with that I've still had problems. I had to re-brace the front bracket on mine too, as the whole bonnet starts to lift off the rads at high speeds.
Spring soon, might be able to meet up for some Welsh runs soon. :)
#93 pete-r
pete-r
  • 2,771 posts
Posted 08 February 2018 - 08:06 AM
It's better now than it was with the old catch. They used to bobble up and down on the corner stands because the catch was a few mm too high but this puts a bit more tension in the panel so it's pulled down more so far so good but it'll probably loosen over time so I'll keep an eye on it.
#94 pete-r
pete-r
  • 2,771 posts
Posted 02 April 2018 - 12:35 AM
Started working on the rear catch, bit trickier because you need to cut away some of the bracing box sections around the pin to get the catch plate inside. Might rebrace it when I'm done and have had the panel painted.
Hopefully no more boot cable issues!
#95 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 03 April 2018 - 03:58 PM
Are you going to make the hinges quick release too? Sent from my Redmi Note 4 using Tapatalk
#96 pete-r
pete-r
  • 2,771 posts
Posted 03 April 2018 - 04:08 PM
Maybe later but no plans at the moment. My mate has fitted some pitking pop catches on his Elise boot but they are a little fiddly to line up. I prefer the idea of screwing tails to the panel which would slide in to the slots where the hinges go. So you could lift it up slightly then remove.
#97 pete-r
pete-r
  • 2,771 posts
Posted 10 March 2019 - 12:27 AM
Not much to update lately, the winter coupled crap weather with working away a lot.
Need to get an ITG I've had in the garage for ages fitted to see if it helps my chances at the National.
Also a new daily has arrived to steal some attention. It's got a core harshness in ride etc but feels much more grown up than the VX. If Bedford is a definite fail I might take it to the national.
In the honeymoon period right now but odds on the VX will be with me long after the Porsche...
Edited by pete-r, 10 March 2019 - 12:28 AM.
#98 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 March 2019 - 08:50 AM
You did this a year ago, but I just found it. Super. Because Im doing the same thing.
Thanks.
#99 pete-r
pete-r
  • 2,771 posts
Posted 12 March 2019 - 12:56 PM
The front was quite easy but the rear was much more complicated because of the bracing.
#100 pete-r
pete-r
  • 2,771 posts
Posted 12 March 2019 - 01:05 PM
Make sure ya u use a hand file for fibreglass to smooth out the cuts without splintering the paint so the finish goes from the picture of the red boot to the blue front. If you use normal tools you might constantly chip the finish.
Once done, I also painted the exposed lips with a clearcoat touch upto stop it splaying or water getting in.
