Dashboard Fit
dash fit
4 replies to this topic
#1 Gopherit
Gopherit
  • 77 posts
Posted 18 April 2015 - 04:48 PM
Have put my Dash back after Fez heater install but really can't decide whether the LHS of the Dash is fitting correctly. Although all the hard-to-get-at screws went back ok there seems to be a large gap. Hopefully the photos tell the story better - I've not got a local VX to compare to.
http://s1341.photobu...y/Dashboard Fit
#2 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 18 April 2015 - 05:24 PM
My dash is far from standard so I can't compare but from memory that doesn't look right at all. Looks like it should be over to the left a bit with the cut out sitting over the windscreen frame more. Although saying that if all the screws are in where they should be I can't see where you're going wrong.
#3 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 18 April 2015 - 07:58 PM
no, that gap is far too wide
#4 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 18 April 2015 - 09:16 PM
Have the two pins at the back centre of th dash seated properly in their holes?
#5 TazN
TazN
  • 2,931 posts
Posted 19 April 2015 - 07:38 PM
There shouldn't be a gap, most likely the pins aren't in place as suggested above.
Also tagged with one or more of these keywords: dash, fit
