Eliseparts Steering Rack Riser Plates
Posted 15 May 2015 - 12:01 AM
Posted 15 May 2015 - 06:31 AM
Just using the pop rivets is enough. They are only there to fixate the plates to fit the bolts/rack but have no real structural function.
Once the bolts are torqued up and everything is sandwiched together it's all solid and not going anywhwere.
The riser plates are just that, fancy 'spreader plates' that provide a single fixed location for the bolts to pass through as the holes in the chassis are elongated so the rack can be moved up and down.
If you wanted to be really cheap you could even drill a new hole in the original plates for a new rivet a little distance from the original hole and (re)use those as raiser plates
Posted 15 May 2015 - 07:37 AM
Sure you're talking about the seperate raiser plates (just 1 rivet) and not the, bonded on the chassis, rack mounting plates with the elongated holes?
Posted 25 May 2015 - 12:13 AM
Edited by Paulus H, 25 May 2015 - 12:13 AM.
