Larini Exhaust Potential Group Buy
#181
Posted 16 June 2015 - 09:51 PM
#182
Posted 17 June 2015 - 09:26 AM
You may need a precat to manifold gasket, the 3 x 10mm flanged nuts to hold the pre cat pipe to manifold, 3 x 8mm x 25mm stainless bolt/nuts/washers to hold the exhaust bend pipe to the cat pipe, exhaust sealant. I guess you get all the clamps with the new box.
Those of you attempting this first, please post where you get all these bits from so I can order them too
#183
Posted 17 June 2015 - 01:50 PM
ebay's the best place for small supplies of stainless bolts
#184
Posted 17 June 2015 - 09:00 PM
Vauxhall Exhaust Front Pipe Gasket Astra Vectra Zafira Downpipe 24454112 on ebay The 3 x 8mm stainless bolts need to be 30mm long if fitting the Larini rear box and there decat pipe as the flanges are thicker then the standard VX ones.Those of you attempting this first, please post where you get all these bits from so I can order them tooYou may need a precat to manifold gasket, the 3 x 10mm flanged nuts to hold the pre cat pipe to manifold, 3 x 8mm x 25mm stainless bolt/nuts/washers to hold the exhaust bend pipe to the cat pipe, exhaust sealant. I guess you get all the clamps with the new box.
#185
Posted 18 June 2015 - 07:47 AM
#186
Posted 18 June 2015 - 07:49 AM
ok guys, just got the heads up from Larini, first batch of systems has gone out.
Order 39125 (Julian) will go a little later as that will have to be combined with a decat, so that's going next week.
I'll let you know about the rest (that's the next batch which we've ask to produce asap.)
#187
Posted 18 June 2015 - 02:48 PM
Same as that 🙌, thanks YvoTukEmail received this morning, item shipped!! �
#188
Posted 18 June 2015 - 03:13 PM
Got the e-mail today confirming shipment. Will arrive just in time for when the car goes to MBR next week. Can't wait.
#189
Posted 18 June 2015 - 08:18 PM
#190
Posted 18 June 2015 - 08:39 PM
^ £600 on an exhaust and then wants to cheap out on the 3 bolts that secure it to the car.
Edited by cressey, 18 June 2015 - 08:40 PM.
#191
Posted 18 June 2015 - 09:05 PM
Ha ha not pinching pennies just wondered if there's a benefit? I know all the stainless bolts that everyone keeps using is reacting with their alloy pretty badly, just wondered why?^ £600 on an exhaust and then wants to cheap out on the 3 bolts that secure it to the car.
#192
Posted 18 June 2015 - 09:12 PM
Think you're mistaken there. It's people using Stainless bolts to secure clams to their aluminium chassis. Using dissimilar metals like this causes them to react. Wherever possible, use the same materials to prevent this type of reaction. Your exhaust will be Stainless so I'd recommend Stainless bolts. You'll also be glad you did if you ever need to remove it.
Edited by cressey, 18 June 2015 - 09:13 PM.
#193
Posted 18 June 2015 - 09:14 PM
Bloody hell I know that 😪, I take it the only benefit is removal then 😇Think you're mistaken there. It's people using Stainless bolts to secure clams to their aluminium chassis. Putting dissimilar metals like this causes them to react. Wherever possible, use the same materials to prevent this type of reaction. Your exhaust will be Stainless so I'd recommend Stainless bolts. You'll also be glad you did if you ever need to remove it.
#194
Posted 18 June 2015 - 09:25 PM
Apologies if that seemed a little condescending then. When you're using slitting discs on your dremel next week to remove your current exhaust, I'm sure you'll shell out the extra pennies for some stainless ones.
#195
Posted 20 June 2015 - 08:42 AM
#196
Posted 20 June 2015 - 08:43 AM
#197
Posted 22 June 2015 - 05:18 PM
Much excite!!! Although I appear to be missing a £700 sports cat?
#198
Posted 22 June 2015 - 05:34 PM
#199
Posted 22 June 2015 - 08:55 PM
#200
Posted 22 June 2015 - 09:24 PM
Is thankyou garage Ben or the lounge 🙌Much excite!!! Although I appear to be missing a £700 sports cat?
