Larini Exhaust Potential Group Buy
257 replies to this topic
#201 cressey
cressey
  • 966 posts
Posted 22 June 2015 - 09:55 PM
My Mrs is asking me the same question. You should see the spare room!
#202 ukcat
ukcat
  • 390 posts
Posted 22 June 2015 - 10:21 PM
Gents - Any fitting tips - Do i need paste on the joints ? Does the silencer sit as in pictures or does it go flat
Cheers
#203 Jezza123
Jezza123
  • 187 posts
  • Interests:Cars !
Posted 23 June 2015 - 12:27 PM
Mines just arrived.  Can't wait to get it fitted.  I lost a lot of love for the car when I took the old one off.
My fitting tip: Get Matt Bentley to do it - assuming that you can get hold of him on the phone to arrange drop off !
#204 fezzasus
Posted 23 June 2015 - 12:38 PM
Cheers
No, don't paste the slip joints, it sits as in the picture.
#205 ukcat
ukcat
  • 390 posts
Posted 23 June 2015 - 12:48 PM
Gents - Any fitting tips - Do i need paste on the joints ? Does the silencer sit as in pictures or does it go flat  Cheers
Ok thanks ive just attempted to fit the first part u bend couldnt get the flange which bolts onto the catalyst section through the hole in the heat shield. Managed to shoehorn it through by slighly enlarging the hole then spent about 2 hours trying to get the bracket on and into the rubber but just wouldnt go !! Do i need to alter the heatdhield more Is the exhaust a tight fit agsinst the shield once fitted ? Ps my necks killin me lol
#206 fezzasus
Posted 23 June 2015 - 01:01 PM
You'll find most people who have fitted aftermarket exhausts have had to cut out the heat shield on both ends because the U bend on other systems tends to be wider. Leave the heat shield loose when you've fitted it.
The rubber mounts bolt to the chassis with 2 x bolts, undo those, fit onto the exhaust, then bolt up.
Edited by fezzasus, 23 June 2015 - 01:02 PM.
#207 ukcat
ukcat
  • 390 posts
Posted 23 June 2015 - 02:09 PM
You'll find most people who have fitted aftermarket exhausts have had to cut out the heat shield on both ends because the U bend on other systems tends to be wider. Leave the heat shield loose when you've fitted it.   The rubber mounts bolt to the chassis with 2 x bolts, undo those, fit onto the exhaust, then bolt up.
Ok cheers has anyone got a pic of how they have cut the shield to give clearance
#208 fezzasus
Posted 23 June 2015 - 02:19 PM
http://z22se.co.uk/t...43#post-1239878
#209 ukcat
ukcat
  • 390 posts
Posted 23 June 2015 - 02:27 PM
http://z22se.co.uk/t...43#post-1239878 Aw cheers seen this one before yeah get the idea was hoping for a pic if an actual larini exhaust to show what cutting was required
#210 cressey
cressey
  • 966 posts
Posted 23 June 2015 - 02:49 PM
Could always use some Vaseline on the rubber to make life a little easier.
#211 ukcat
ukcat
  • 390 posts
Posted 23 June 2015 - 02:56 PM
No probs getting the support bars into the rubber its just the fitting of everything into the oem shield i was wanting some advise from someone who has fitted a larini backbox into an oem shield. Just basically how much and what needed cutting away and hopefully a pic Cheers
#212 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 23 June 2015 - 03:44 PM
Sorry can't help you, but I take it the rear silencer ahem fits vertical not flat?
#213 cressey
cressey
  • 966 posts
Posted 23 June 2015 - 05:16 PM
Guess flat would be more preferable than vertical for flow but guess the best position is wherever it has most clearance really so you don't scorch anything. Does this sound condescending again?
#214 fezzasus
Posted 23 June 2015 - 05:55 PM
Pretty sure the gas don't know which way up it is.
#215 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 23 June 2015 - 06:51 PM
Yes it does sound condescending again 😂,I suppose like fezz says the gas isn't really bothered either way, it's quite a tiny rear box compared to standard and the blueflame equivalent so space will not be that much of an issue.....Excited, mine has come today, and I'm off tomorrow 🙌
#216 VX220BOB
VX220BOB
  • 625 posts
Posted 23 June 2015 - 08:04 PM
I fitted mine vertical as it seemed easier to fit.
#217 ukcat
ukcat
  • 390 posts
Posted 23 June 2015 - 08:25 PM
Guys is there any chance one of you could take a couple of pics once your fitted yours - Just want to see another one fitted - Would be very much appreciated
Tony
#218 cressey
cressey
  • 966 posts
Posted 23 June 2015 - 08:32 PM
Jealous. I'm still waiting for my sports cat. Been under the silver one all evening replacing discs and pads and bleeding the brakes. Hopefully make some progress on the blue one next week. Should be making the airbox next week too.
#219 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 24 June 2015 - 12:04 PM
Well, what a crap job, trying to get the tips lined up is an episode in itself....as someone stated earlier in the group buy the tail pipe clip is a mare, wonder just how tight you can go on it. Plan some time if your tackling this as a novice.
#220 ukcat
ukcat
  • 390 posts
Posted 24 June 2015 - 05:08 PM
Thats an understatement ive been on with mine all day basically fitting without the heat shield to get an idea of where i need to modify/cut the shield absolute nightmare currently got it in place but no way i can get the tailpipes plumb bit disapointed at mo as was expecting a better easier fit !! Looking at it at moment the hanger brackets are higher than the shield level:-( the u bend from cat pipe is actualy more than 180 degrees so the silencer does not run parallel to the subframe gona just shut the garage door and have a beer and have another go tomorrow
