Oil Return Pipe Leaking On Turbo
22 replies to this topic
#1 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
  • Location:Inside my turbo its a beautiful place you know
  • Interests:Working on the VX ,alcohol, drunk street fighting with Rudy. life doesn't get much better than that
Posted 31 May 2015 - 11:11 AM
Had a oil burning smell for about 5-6 weeks now, stripped down various parts to see what was causing it but never noticed anything, then I got a camera endascope and stuck the camera in under the turbo, the tube running from the turbo, expandable flexi pipe has oil over it, looked further and oil is seeping out around the fixing flange, the bolts are not lose that fixes it in place. Question is how hard is it to strip down and replace what looks like gasket leaks, what do I need to do to replace and fix the problem. Not a clam off job I hope😠 information helpful thanks
#2 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 31 May 2015 - 11:46 AM
I bought the upgraded pipe from CS and you can fit it from under the car.
Its tight you will hate the car afterwards but it can be done.
This?
http://www.courtenay...s/prod_840.html
Edited by mbes2, 31 May 2015 - 11:47 AM.
#3 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 31 May 2015 - 11:58 AM
You could try changing the gasket for it. Cant remember there been any difference between the original metal and later Leh oil return pipe Its not that hard to change and more a fiddle due to space Just check its not your turbo oil seal leaking before changing DG
#4 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 01:24 PM
Got any photos anyone, I will slide under the car and take a photo of what I have got
#5 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 02:14 PM
#6 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 02:23 PM
#7 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 02:24 PM
This is what it looks like, any ideas, the pipe work does not look easy to get to, is it oil pipe or turbo seal??
#8 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 03:13 PM
Cleaned off all oil reminence so nice and dry around the turbo fixing nuts and flange plate, run car on tick over for 15 mins and not a sign of any oil leakage, so can the turbo seals or the fixings show oil leakage under turbo load??
#9 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 31 May 2015 - 06:48 PM
Found the leak now, it was the oil return pipe😀 shouldn't really be happy about having to remove the return pipe but at least I know what it was, stupid gaskets but at least that's the leak. Will order the gaskets tomorrow and fit through the week.
#10 Nev
Posted 01 June 2015 - 11:25 AM
Why not nip up the 2 existing bolts , it will quite possibly fix the issue if they were a bit lose, without having to get covered in oil and un-necessarily changing the gasket ?
#11 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 01 June 2015 - 04:35 PM
Alsmost certainly not fix Nev in my experience but worth a try to see if it can be tightened a touch DG
#12 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 01 June 2015 - 05:00 PM
Tried it yesterday, could not tighten them any more and still leaked, went to the stealers. today and brought the 19tdi gasket as well as the OEM one as they had them both in stock. As the weather is crap over the next two days I will look at changing Thursday. Any helpful tips on how to get to the bolt head close to the engine easier would be helpful.
#13 Nev
Posted 01 June 2015 - 05:17 PM
Should be easy enough to reach in there with a UJ and some extender bars surely?
Good luck.
Edited by Nev, 01 June 2015 - 05:17 PM.
#14 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 01 June 2015 - 05:18 PM
Bottom return bolt off move pipe to side. Usual heat shield bits off etc and with the correct extension its fairly easy other than the usual vx220 do it blind. Been a while so could not say what combo I used last time The correct size 1/4 inch ratchet and socket is a cheat option iirc not sure if it was imperial to cover that size Have fun DG
#15 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 01 June 2015 - 05:57 PM
Looking forward to it, at least if I do it I know it will be done correctly. Think while I am there I will drop in the cool running stat👍
#16 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 01 June 2015 - 06:05 PM
Ref the cool running stat are you having temp issues? I found it ran too cool back in the day when I had one and went for a new oem jobbie. Wired in fan overide for extra paranoid moments. Did run low temp one for the 3 week tours around europe but its proper hot there down souuuthhh and was in reg 30+ deg all day and traffic was very hot lol In winter cool stat too low imo DG
#17 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 01 June 2015 - 06:50 PM
Your right the cool stat runs low, took it on track at Goodwood last week with Martin S driving, temps got up to 104 and so thought it should be cooler running if I put in the stat. I am going to check everything when I have the car raised up. Spoke with last owner and he said it never went any higher than 98 when he had a run on track, although Martin was giving it major beans😂😂
#18 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 01 June 2015 - 07:31 PM
You need to get your bits sorted mate, that temp doesn't sound right. I reckon a proper shakedown before the National will sort the final bits and turn your show car into more of a track weapon :) Have a couple of track days lined up for July and August - I'll drop you a PM later in the week ok.
#19 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 02 June 2015 - 08:42 PM
Got a call from Ollie2007 earlier. Went something along the lines of - "The fckin stupid sh!ttin plastic sh!tbox, fckin wnking pile of plastic fckin fckin sh!t" 5 minutes of ranting :lol: Think he's done it but he hates the car now lol
#20 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 04 June 2015 - 08:51 PM
Yep all done, now waiting for oil to arrive to do an oil change 10w50 silkoline S and new filter, second filter and oil change in less than 6 months. going to do an intercooler air pass modification as well Saturday, its still a fukcing sh*tbox plastic wnking piece of fuking sh;t though, but I love her so she will be worth it in the end, oh and the fuking spanner rash.
