Here is my old inlet camshaft off my Astra Vxr still in perfect working order
Taken out due to having highlift cams put in ..cam lobe measures 46.78mm
£100
Z20 Leh Astra Vxr Inlet Cam
Started by
Jordyp33
, Jun 04 2015 02:13 PM
inlet cam camshaft astra vxr z20leh
4 replies to this topic
Posted 04 June 2015 - 02:13 PM
Posted 05 June 2015 - 08:55 PM
£100 for a single standard camshaft? Isn't that a little optimistic when you can buy a whole Z20LET engine for £250(which has the same camshafts)?
Edited by Nev, 05 June 2015 - 08:56 PM.
Posted 08 June 2015 - 09:17 PM
If you can get a whole zlet engine for £250 I'll have 3 😊 lol don't these cams work well in the vx220's
Posted 09 June 2015 - 05:34 AM
Almost certain cams the same as the let as the leh, was sooooo long ago I measured mine I cant remember. The older inlet cam off z20xe is the one people sometimes use as an upgrade. The xev one is also used but sure I remember it needing timing half a tooth so the pulley needs sorting
So afraid its not really an upgrade just a spare. In the past I have seen a few sets of std cams go for 50-100.
Hope this helps to clarify
DG
Posted 11 June 2015 - 05:32 PM
Easy really, just go on eBay, and offer that to the 40 hopefuls trying to repeatedly sell their Z20LETs for £500 for 6 months the trot... I bought a Z20LET for £300 over 5 years ago (when there were far fewer around). The market is now flooded with them cos the 10s of thousands of Astras and things they were put in are coming to end of life. The XEV inlet cam is the one that is more desirable, it lifts the inlet valves and extra 1mm, but as Duncan says, it needs advancing about 8 degrees, which would require a vernier pulley and bit of fiddling. In standard Z20LET factory tune, the gains are around 8 BHP mid range and about 4 BHP top end.If you can get a whole zlet engine for £250 I'll have 3 😊 lol don't these cams work well in the vx220's
Edited by Nev, 11 June 2015 - 05:39 PM.
Also tagged with one or more of these keywords: inlet cam camshaft astra vxr, z20leh
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 conversion, swap, ecu, loom and 2 more... |
The Market Place →
Car Parts Wanted →
Z20Let Or Leh WantedStarted by HOLTY , 03 Feb 2015 z20let, z20leh, engine |
VX220 Discussion →
Z20Lex BibleStarted by Nev , 17 Sep 2014 z20let, z20leh, fix, mend and 6 more... |
Tuning & Modifications →
Machining Block For Z20Leh Oil SquirtersStarted by cnrandall , 25 Aug 2013 z20leh, oil squirters, block and 1 more... |
Some Qs About Fitting A Thicker Head Gasket Z20Le*Started by dedko , 30 Mar 2012 head gasket, z20let, z20leh and 1 more... |
