it looks a bit wonky.
Looks like the side fins are bent to 90 degrees and then bent back to make it 100-110, but that bends the top surface of the diffuser rather than open up the angle. so there is that slightly awkward lip up before the 90 degree bend. I'd bend it less in the first place
The fins look a bit odd too. the mix of straight lines and curve doesn't quite work. I'd give them a single curve
it doesn't look like the diffuser is sitting flush with the clam. not sure how to fix it, it looks too wide for the clam aperture, partly because you've used right angles at the edge rather than a curve to match the clam.
needs a bit more thought imo, but good effort.
Without sounding defensive.....
Not sure what you mean by "wonky" the diffuser rear edge is 20mm short of the rear clam all the way around I will try and get a photo from underneath.
The bends are at about 100deg and were done professionally at the fabricators so are perfectly flat, think its the angle of the photo and the profile! if you look at the third picky down you can see there is no kink!
I personally didnt like the curve ending at the bend thats why I put a little flat to sharpen it up but I suppose its just personal preference....
The only way to finish flush with the rear clam is to bend it up as the clam has a slight radius underneath! the TAT ones (well the ones Ive seen) do the same but yeah maybe with the curves on the edge it would be a little closer.
Im looking into the curved edges
Thanks for the comments
