Lotus Store On Motorsportauctions.com
#241
Posted 01 July 2015 - 11:19 AM
#242
Posted 01 July 2015 - 12:20 PM
Can´t resist... Bought drive shaft, main harness and gear cables.
No gear cables, all sold out. So tomorrow my gear cables will fail.
#243
Posted 01 July 2015 - 01:07 PM
#244
Posted 01 July 2015 - 01:18 PM
No worries, intention was to buy them just in case. Current cables are still fine but thank you for the offer .
#245
Posted 01 July 2015 - 03:58 PM
I purchased what I thought were NA shocks from motorsportauctions. I have received what the part number identifies as VXR shocks. Lotus are saying they are the same as the NA shocks.
Can the knowledge of .org please confirm if this is correct?
Thanks
Hi JD,
Did you confirm if the shocks were OK for your NA VX after?
Probably going to order a set, but would be nice to know they fit (otherwise I'll be wondering what I've done wrong in 6 months time when I get around to fitting them and they maybe don't! )
Cheers mate
#246
Posted 01 July 2015 - 06:44 PM
#247
Posted 01 July 2015 - 07:10 PM
HWK,
Had a reply that made sense. Basically the shocks and springs have separate part numbers, but when ordered as a single unit have a completely different number. This part number is the same as the VXR number in the EPC.
I've decided to keep the shocks as others have had the same reply. Although not 100% sure, but other research I've done indicates this is probably true.
#248
Posted 01 July 2015 - 07:27 PM
#249
Posted 01 July 2015 - 09:02 PM
#250
Posted 01 July 2015 - 10:10 PM
Thanks for the info Chappers. I know next to nothing about suspension, but from searching that looks a lot stiffer than std n/a values: Old info from spring rate thread (2003)- VX220 NA = 234 / 268 lbs/in = 42 / 48 N/mm New ones supplied 47.5N/mm and 65 for the rear 420 lbs/in F 575 lbs/in R Will this make it feel like riding on a tram?The na shocks I got say front springs are 47.5N/mm and 65 for the rear. Not sure what my current ones are.
#251
Posted 01 July 2015 - 11:45 PM
#252
Posted 01 July 2015 - 11:53 PM
#253
Posted 02 July 2015 - 05:58 PM
They sound similar rates to an Exige, have a look here, about halfway down under S2 Spring Rates:
http://wiki.seloc.or...ension_upgrades
I assume they will be stiffer than the standard VX springs, my Elise R shocks and springs are stiffer than the standard turbo, but not as stiff as Exige, so you are welcome to have a ride in mine to see how stiff it is, although I can't find the rates for them, and my car is tubby as well.
Don't the N/A's have stiffer rates than the Tubby anyway, so the difference might not be too great for you.
Edited by .Adam., 02 July 2015 - 05:59 PM.
#254
Posted 02 July 2015 - 08:27 PM
When someone has fitted these shocks can they post the results on here?
I like the idea of fitting new OEM, but don't want to turn the car into a boneshaker.
#255
Posted 02 July 2015 - 08:41 PM
#257
Posted 02 July 2015 - 09:00 PM
Just tried a different converter that said 47.5 and 65 N/mm equal 271 and 371 llb/inch. Is that right?
I must have used a chinese converter or something ,
Your numbers look good.
I've just ordered a set
#258
Posted 02 July 2015 - 09:19 PM
#259
Posted 02 July 2015 - 09:22 PM
YesAlmost certainly a stupid question but could those who know please tell me whether I can just buy a hardtop from here and pop it in place of my soft top, or whether there is more to it than the two being interchangeable? Thanks all
#260
Posted 02 July 2015 - 09:37 PM
Thanks...but "yes" they are interchangeable, or "yes" there is more to it??
