Nitron Street Series 2 - Part Numbers And Mounts Question
4 replies to this topic
#1 rik
rik
  • 2,187 posts
Posted 19 June 2015 - 01:53 PM
Just picked up a set of nitron street series 2 since my sachs are nackered
I notice each shock has a different part number -
Fronts:
SS4138
SS4139
Rears:
SS4330
SS4331
How do I know which to use each side?
Also came with new front top mounting brackets and an extra, longer, set of mounting screw/bush things- do they want me to use the longer ones but provide the shorter ones just in case you don't want to replace the mounting brackets too?
#2 siztenboots
  • 26,613 posts
Posted 19 June 2015 - 02:06 PM
ss numbers are the serial numbers so Nitron can track every shock they make
#3 siztenboots
  • 26,613 posts
Posted 19 June 2015 - 02:08 PM
mounting brackets are wider than original to give clearance to the shock body long shocks go on rear shorts go on front there is no left or right side , just fit them with spring at the bottom.
#4 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 19 June 2015 - 02:09 PM
They are serial numbers shocks are not side specific. I used both the front brackets along with the larger centering mounts supplied. You should be able to re-use the existing bolts, SeriouslyLotus where kind enough to throw a new set in with mine but for t he minimal cost you may as well whack some new ones on. Don't forget to use some red rubber grease around the O rings before fitting.
Edited by -Dab-of-Oppo-, 19 June 2015 - 02:11 PM.
#5 rik
rik
  • 2,187 posts
Posted 19 June 2015 - 02:10 PM
thanks all, question answered :)
