Bad Rear Vibration
driveshaft
26 replies to this topic
#1 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 02:22 PM
Car has delevoped a bad vibration from the rear passenger side, almost feels like something is stuck on the rear tyre, and it clunks as it goes round. There seams to be a lot of oil/grease around the inner driveshaft boot area. Rear hub has been replaced, and the vibration seems to get better when i take the car out of gear but still going forward. Iv taken it to my local MOT place that I trust, and they looked at balancing the rear wheel again, but it was fine. Does this all point to the rear oil seal giving out and need replacing, or the driveshaft, or both?
#2 fiveoclock
fiveoclock
  • 9,453 posts
Posted 09 August 2015 - 02:26 PM
Sounds like the diff to me. I had exactly this and that's what it was
#3 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 02:28 PM
Seems to have got worse recently, and when i go around a roundabout, i can hear waht sounds like something flapping about abit. Im guessing the diff is a gox off job.
#4 techieboy
Posted 09 August 2015 - 02:30 PM
CV joint is fubar by the sound of it.
#5 fiveoclock
fiveoclock
  • 9,453 posts
Posted 09 August 2015 - 02:31 PM
Certainly is. Is it worse when you're on the power and off the power and better on a balanced throttle?
#6 fiveoclock
fiveoclock
  • 9,453 posts
Posted 09 August 2015 - 02:34 PM
Start checking at the hub and work your way in
#7 fiveoclock
fiveoclock
  • 9,453 posts
Posted 09 August 2015 - 02:37 PM
If it is you've just missed out on the cheap drive shafts Lotus were selling too
#8 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 02:39 PM
Its still there on a balanced throttle, doing 50-60mph, its quite bad in 5th, and i knock it out of gear, and it seems to go away. Hub was replaced recently, and when i checked it the other day, all seemed well with that. Is the CV joint near the oil seal area? Iv cleaned up alot of grease/ oil around the inner boot area, as well as the inside of the rear passenger wheel
#9 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 09 August 2015 - 02:40 PM
Sorry just typed a load of tripe its been a long day lol
Edited by jonnyboy, 09 August 2015 - 02:41 PM.
#10 D-DAWG83
D-DAWG83
  • 1,276 posts
Thanks! lol
#11 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 02:41 PM
Have you had the wheel off lately? The old ABS bracket hitting a wheel weight is a good one.
Wheel weight is in on piece, and looks untouched to me. Iv also got 17" rears, so hope its not that
#12 techieboy
Posted 09 August 2015 - 02:44 PM
The inner boot is secured to the inner CV joint at the larger end and is there to hold in the grease for the joint. If it's grease you've been clearing up, rather than much thinner (red/orange) oil, then it's more likely to be the CV joint. Mine knocked like a good 'un at an Anglesea National a few years back, especially when the nearside loaded up under cornering.
#13 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 02:54 PM
Yes, going round roundabouts (of which there are alot in MK), it sounds worse. Could it be a new driveshaft job then? Autovaux the best place to get one?
#14 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 August 2015 - 03:07 PM
Pm Paul CP I think he may still have my old drive shafts for sale only done 40k , Be quick as he is on the French Frolic soon
#15 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 03:09 PM
Did you replace yours for new? Mine has only done 50k,so a little surprised, but just spent a fortune on the plastic box of joy, so any savings would be welcome if possible
#16 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 August 2015 - 03:14 PM
 [color=rgb(34,34,34);][font="'Helvetica Neue';"]
Did you replace yours for new? Mine has only done 50k,so a little surprised, but just spent a fortune on the plastic box of joy, so any savings would be welcome if possible[/color][/font]
I did a gear box conversion had to use different drive shafts, My old shafts are in vgc
Edited by Kieran McC, 09 August 2015 - 03:14 PM.
#17 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 03:15 PM
[color=rgb(34,34,34);][font="'Helvetica Neue';"]Did you replace yours for new? Mine has only done 50k,so a little surprised, but just spent a fortune on the plastic box of joy, so any savings would be welcome if possible[/color][/font]
Cheers, iv dropped him a PM. Will I need new oil seals as well?
#18 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 August 2015 - 03:24 PM
I would change them belt and braces
#19 CHILL Gone DUTCH
Posted 09 August 2015 - 03:26 PM
Check the castle nut is tight on the end of drive shaft After removing split pin 😜
Edited by CHILL Gone DUTCH, 09 August 2015 - 03:27 PM.
#20 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 August 2015 - 03:28 PM
It can't move if the split pin is in place
Also tagged with one or more of these keywords: driveshaft
