Bad Rear Vibration
driveshaft
26 replies to this topic
#21 CHILL Gone DUTCH
Posted 09 August 2015 - 03:30 PM
Check the castle nut is tight on the end of drive shaft After removing split pin 😜
It can't move if the split pin is in place
That's if it was tightened before the pin was put in
#22 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 03:45 PM
I was able to tighten the castlenut by a small amount, but the spilt pin was in place, however, iv still got the vibration from the rear.
#23 CHILL Gone DUTCH
Posted 09 August 2015 - 03:47 PM
Remove the pin and try to tighten it further And put pin back
#24 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 03:49 PM
Did that the other day, and it is still making the noise/vibration. However, will try again tomorrow.
#25 fiveoclock
fiveoclock
  • 9,453 posts
Posted 09 August 2015 - 04:17 PM
Check that it is the drive shaft before buying a replacement
#26 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 09 August 2015 - 04:20 PM
How do i go about doing that? Shall i push the shaft in, and see if it has some movement in it or something?
#27 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 10 August 2015 - 01:00 PM
Picking some new shafts up from Paul CP later today, with the hope to get atleast the passenger side fitted before Friday. Il order a pair of driveshaft seals also, incase I need to do them. Is there a specific grease or lube i should use when doing these?
Also tagged with one or more of these keywords: driveshaft
