Best Seats
seats
54 replies to this topic
#21 Bargi
Bargi
  • 4,483 posts
Posted 19 August 2015 - 12:12 PM
Check what Keiran has then. I sat in his and my arse cheeks fell over the sides ☺
#22 FLD
Posted 19 August 2015 - 12:22 PM
Does anyone have those corbeau VXR-alike seats?
#23 jinxy220
jinxy220
  • 96 posts
Posted 19 August 2015 - 10:09 PM
Yep, me. Reasonably priced compared to alternatives, comfy, supportive, proper holes for harness, lightweight and look good. You do need Elise subframes to fit easily though, without modding existing mounts.
#24 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 20 August 2015 - 04:49 AM
How are they for lateral support, dont look like they grip you much.
#25 jinxy220
jinxy220
  • 96 posts
Posted 20 August 2015 - 06:02 AM
I find them supportive, not being leather you slide around less! Not sure how you could have a seat with larger bolsters in the VX as it would be difficult to get in/out. I also use the 4 point harness on the track so stuck in place well.
#26 FLD
Posted 20 August 2015 - 06:18 AM
Look good thumbsup
#27 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 August 2015 - 07:55 AM
Op
.. you want to speak with siztenboot aka steve...
He has the seats that would hold you in..
Trying to find a photo for you of one..
Edited by mbes2, 20 August 2015 - 08:20 AM.
#28 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 20 August 2015 - 09:06 AM
They look great, how much do they weigh?
#29 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 20 August 2015 - 10:08 AM
Can you use the seats with standard belts, as thats a must for me also. Any idea where you got them from and how much?
#30 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 20 August 2015 - 11:55 AM
These just arrived  :wub:
They definitely hold you in. Shame I can't even sit in them  :angry:
#31 sford
sford
  • 1,454 posts
Posted 20 August 2015 - 12:33 PM
Which sub frames do you need to fit these? And is there any butchery involved or do the bolts all fit fine? I'm about 80% there with a set of these in mind, as soon as I get close I read a thread about re-drilling holes etc and think screw it.
#32 jinxy220
jinxy220
  • 96 posts
Posted 20 August 2015 - 01:10 PM
I didn't weigh them, but an article on the website below I read before buying them says "6.5kg's each (without the seatframe). The original seat is 7.4kg."
https://www.verboom....0206/index.html
#33 jinxy220
jinxy220
  • 96 posts
Posted 20 August 2015 - 01:14 PM
I did a bit of research online and found they are only direct fit for the early S1 Elise/Exige. So you will need to source a set of early S1 subframes as the bolt positions are slightly different to the VX/Elise S2, luckily the S1 subframes bolt straight into the VX, it is just the upright side mounts that bolt into the seat that are at a slightly different position.
You can butcher the original subframes & drill etc but I wanted the option to revert back to standard seats when I eventually sell the VX.
#34 sford
sford
  • 1,454 posts
Posted 20 August 2015 - 01:16 PM
That was the link I read about the washers and issues. What sub frames did you use jinxy?
Edit: Saw your reply after I posted. Cheers.
Edited by sford, 20 August 2015 - 01:16 PM.
#35 jinxy220
jinxy220
  • 96 posts
Yes, I have both 4-points and seatbelt fitted still. The harnesses are tucked away behind the seat for road use and original seatbelt still usable.
#36 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 20 August 2015 - 01:18 PM
Sounds like a good alternative to me. What about a harness bar behind them?
#37 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 20 August 2015 - 01:19 PM
Just seen these on FB, look amazing. Im a sucker for carbon, can you post a photo of the weave close up, especially round the sharper corners. I wonder if they are wet lay, or proper pre preg carbon.
#38 jinxy220
jinxy220
  • 96 posts
Posted 20 August 2015 - 01:23 PM
Jon Betts harness bar - do a search on here.
#39 jinxy220
jinxy220
  • 96 posts
Posted 20 August 2015 - 01:25 PM
Here is the differences between the subframes.
#40 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 20 August 2015 - 03:52 PM
Thats what iv got, so i should be alright then. Will have to see if i can get a sit in one at some point. Are they alot better than the standard seats, and worth the cash?
Also tagged with one or more of these keywords: seats
