Edited by jimgraham, 15 September 2004 - 08:50 AM.
Bang! - sh*t My Shorts, What Was That!?
Posted 15 September 2004 - 08:48 AM
Posted 15 September 2004 - 09:05 AM
Posted 15 September 2004 - 09:20 AM
#4 Guest_Vermania (Guest)
Posted 15 September 2004 - 10:24 AM
Posted 15 September 2004 - 10:25 AM
Edited by mcarrick69, 15 September 2004 - 10:25 AM.
Posted 15 September 2004 - 10:30 AM
Again, covered a number of times.My spring is a bit squeaky and probably expecting it to snap sometime soon. When this happens is the car still drivable? Does the clutch pedal callapse to the floor or what will happen?
If it is going to be a pain in the a**e then I'll change it before it snaps!
The noise it makes is disconcerting. It is noisey because the broken spring flies off and hits an Aluminum dash, which is noisey.
It is a bit of a jump when it goes, but generally you realise VERY quickly what has happened and it doesn't worry you too much.
The spring will creak from new, so this is not a sign of impending doom.
My second went recently on our tour around France. I reckon I did 200 miles with a snapped spring. Only the pedal pressure is different, and if you tend to ride the clutch at all then it might feel like you are getting clutch slip.
Some people have experienced problems when the spring goes because the bite point is sooo high up the pedal, but the main difference for most people is the pedal feel. I prefer the sprung pedal feel myself, but others have stated that they prefer the feel of the pedal without spring.
I haven't heard of any of the new springs going, but it could be early days yet.
HTH
Steve
Posted 15 September 2004 - 10:34 AM
Mine went a couple of months ago. Yes, it is very loud, sounds like your engine has popped and blown up. You can still drive it fine, but it does need sorting asap. The only difference that you will notice is that the gears clunk in to place, as though the clutch isn't quite pressed in enough.My spring is a bit squeaky and probably expecting it to snap sometime soon. When this happens is the car still drivable? Does the clutch pedal callapse to the floor or what will happen?
Posted 15 September 2004 - 11:17 AM
Posted 15 September 2004 - 11:21 AM
Posted 15 September 2004 - 11:55 AM
I don't really give a sh*t whether this has been covered loads of times or not, but thanks for the advice Gedi, it was really handy and much appreciated.This has been covered about 5 million times, there are even pics of new and old springs.
The sound is like a shotgun and made me jump. I was reversing my car at the time, so thought i had hit something!
You can get replacement springs from dealers. My dealer gave me the thing free as he said it wasn't worth the cost of invoicing me for! (5p)
I had to bend one end of the spring out slightly to fit it onto the clutch when i did it last night. The clutch bar was thicker than the opening in the spring, but it is a very simple job. I just hope i haven't weakened the end of it!
Cheers,
Jim
Posted 15 September 2004 - 12:29 PM
If everyone had that way of thinking, we may as well get rid of the search button.I don't really give a sh*t whether this has been covered loads of times or not
Thankfully they don't and the board is fresher for it.
Posted 15 September 2004 - 12:51 PM
I really don't understand the attitude on this forum that makes a fopah out of starting a thread on something that has been discussed before. Not all of us spend our life monitoring what is discussed here.If everyone had that way of thinking, we may as well get rid of the search button.I don't really give a sh*t whether this has been covered loads of times or not
It was obvious in the title what the thread was about, so if you knew you had been through this loads of times why did you bother reading it/ replying to it? (i am glad you did as the info was useful by the way).
From the conversation the thread has generated it is obvious that there were things to discuss, so what is your problem?
I thought the forum was all obout being able to chat about things you wanted to chat about, not for apologising for not searching for half an hour before posting.
Edited by jimgraham, 15 September 2004 - 12:56 PM.
Posted 15 September 2004 - 01:05 PM
Posted 15 September 2004 - 01:10 PM
It took me 25 secs to find a previous post about this topic using the search function. Surely that was quicker than you having to type in the post in the first place ?I really don't understand the attitude on this forum that makes a fopah out of starting a thread on something that has been discussed before. Not all of us spend our life monitoring what is discussed here.
Posted 15 September 2004 - 01:24 PM
Don't read it if you think it will be tedious, you don't have to read everything. I reiterate the fact that the post clearly stated what it was about. I simply don't read posts if i think i have read it before or am bored by the subject.No problem, I'm still smiling whilst typing.so what is your problem?
It's just tedious to see the same thing over and over, esspeically when Ben wrote a novel on the topic >here<
Has this descussion been held before? have we searched?
That is a good point. I was being lazy as it takes a lot longer than 25 seconds to read through all the previous posts to find out if it contains the exact info i want. I also thought that someone wouldn't mind just tapping in the answer to my questions.
I still dont understand why people get so excited about recouring posts when they have a choice whether to read them or not. Live and let live, may be I haven't discussed this before. Just because you guys have and are bored with the topic doesn't mean everyone is. The new guys may want to chat about it as well.
Jim
Posted 15 September 2004 - 01:28 PM
Posted 15 September 2004 - 01:30 PM
That's FAQ not !
Posted 15 September 2004 - 01:42 PM
Posted 17 September 2004 - 02:23 PM
