Dash Light Switches, Help!
14 replies to this topic
#1 gav89
gav89
  • 215 posts
Posted 02 September 2015 - 10:25 PM
Okkkkkkk, so I want to change the dash light switches cos .....they look sh!t basically. yes, yes I know, you only look at them once or twice per journey etc etc, but personally I think they look like they are from a crappy smart car and dont wanna look at their ugly faces anymore. So I'm appealing to an electrical genius to give me an idiot guide to working this wiring out.
IE....What does each colour wire correspond to? Lets just pretend you are explaining this to a 5year old....that would be perfect thanks :-)))
Here are the pics of each relay..........
HAZARDS
FRONT FOGS
REAR FOGS
MAIN BEAM
SIDELIGHTS
#2 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 02 September 2015 - 11:02 PM
Sidelights Green - feed from fuse 7, lights switch when ignition on, out on black Brown/blue - feed from fuse 19, press the switch and it connects to red/blue to relay k20 Red/blue Black
#3 Zoobeef
Zoobeef
  • 11,103 posts
Posted 02 September 2015 - 11:09 PM
Main beam Green and black same as above Brown/blue - feed from fuse 19, blue then takes the power to relay k19.
#4 Zoobeef
Zoobeef
  • 11,103 posts
Posted 02 September 2015 - 11:16 PM
Rear fogs Red/green - black = lights switch when sidelights on. Red/blue - grey = when button pressed connects fuse 1 to relay k5 Red/yellow = a feed returning from relay k5 to light the second bulb in the switch.
#5 Zoobeef
Zoobeef
  • 11,103 posts
Posted 02 September 2015 - 11:23 PM
Hazards Green/red - right hand indicator bulbs Green/white - left hand indicator bulbs Black - earth from switch bulb Violet/brown - to flasher relay Violet - from fuse 9 Green - from fuse 6 Green/white - from flasher relay
#6 gav89
gav89
  • 215 posts
Posted 02 September 2015 - 11:28 PM
Sheeeeeeeeeeeeeeeeeeeeeeeeeet Thats pretty dam comprehensive thanks man, thats much appreciated!
Do you think its possible to change all the switches to these....http://www.ebay.co.u...=item1c33c81d1a
#7 Zoobeef
Zoobeef
  • 11,103 posts
Posted 02 September 2015 - 11:35 PM
Front fogs<br /><br />Red/green - black = feed from side lights and earth. Lights switch light.<br /><br />Blue - feed from light switch<br /><br />Red/violet - to relay k4
#8 Zoobeef
Zoobeef
  • 11,103 posts
Posted 02 September 2015 - 11:38 PM
Should be able to use those. Anything is possible with electricary magic. Looking through the diagrams has reminded me I need to just print them all out.
#9 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 03 September 2015 - 04:05 AM
Yes it's possible and I have used those very switches. Only slight ball ache is the hazards as you could do with an extra normally closed pin to do a straight swap but it's still workable.
#10 GiGo
GiGo
  • 5,657 posts
Posted 03 September 2015 - 06:50 AM
Really wish you would make me a set of those ;) They look :wub:
#11 gav89
gav89
  • 215 posts
Posted 03 September 2015 - 05:18 PM
Thanks man, your helps been muchos appreciated, I'll give this mine field a go and see what happens .......A few fuses blowing id imagine but fortune favours the brave :-)))
#12 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 27 June 2018 - 11:18 AM
Thank goodness for threads like this..
Godsave Org
#13 pete-r
pete-r
  • 2,771 posts
Posted 28 June 2018 - 06:11 PM
Originally I wanted to use these In my car but the wiring was way too complex.
So went for these instead and very happy with them.
#14 Pidgeon
Pidgeon
  • 5,254 posts
Posted 29 June 2018 - 07:35 AM
Jonny/Chris, a menu price for replacing the switch panel and switches, fully fitted would be of interest :D
#15 VincentL
VincentL
  • 133 posts
Posted 29 June 2018 - 08:24 AM
I would long the dab-of-oppo version as I'm just about to hook up abs and fan switched
