Wipers Not Working
any ideas
12 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 19 September 2015 - 10:56 AM
Its not the fuse, so that's me stumped!
Martin S
#2 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 19 September 2015 - 11:29 AM
Failed wiper motor?
#3 PaulCP
PaulCP
  • 6,066 posts
Posted 19 September 2015 - 12:31 PM
Switch? Check for power at the motor, 2 min job
#4 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 19 September 2015 - 01:48 PM
need to getb a multi meter I guess, where is te relay for the wiper, under the r h side of the dash?
#5 Kieran McC
Kieran McC
  • 3,416 posts
Posted 19 September 2015 - 01:57 PM
K10 relay under the passenger's footwell
#6 Kieran McC
Kieran McC
  • 3,416 posts
Posted 19 September 2015 - 01:59 PM
Relay K10 under passengers footwell
#7 PaulCP
PaulCP
  • 6,066 posts
Posted 19 September 2015 - 03:09 PM
Martin, easy bit first is to check for power at the motor itself. Take of the plastic cover & you will see the connections. Use a 12v probe if you have one. Don't know off hand which connector is which but you should be able to figure it out with the probe. You can work backwards from there if there's no live feed when you switch the wipers on
Edited by PaulCP, 19 September 2015 - 03:11 PM.
#8 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 19 September 2015 - 04:28 PM
Swap the relay with Lauren. Or get a VW one anyway if you don't have one. I may still have a standard relay somewhere. If still nothing then as paul says check for power at the motor. That will tell you if it's the motor or wiring/stalk.
#9 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 20 September 2015 - 10:10 AM
I have power at the motor, so I'm guessing them motors dead. Ho hum.
Martin S
#10 PaulCP
PaulCP
  • 6,066 posts
Posted 20 September 2015 - 11:56 AM
Could be stuck, try moving the wiper arm by hand with the wipers switched on. But, even if it is stuck it's not a good sign😟😟
#11 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 22 September 2015 - 03:48 PM
New motor installed (second hand one to be precise). Took about 40 mins thanks to the guide on here.
Martin s
#12 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 23 September 2015 - 12:21 PM
On occasion the original one can be dismantled, cleaned out and that repairs it.
#13 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Also tagged with one or more of these keywords: any ideas
