Oem Gm Gearbox Breather Part Numbers
gearbox breather oil wheel gearbox breather
8 replies to this topic
#1 thejoaoserra
thejoaoserra
  • 216 posts
Posted 20 September 2015 - 11:07 AM
Full kit consists in the following parts:
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]1 - Breather Screw - 90086885 [/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]2 - Vent Nipple - 90157801[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]3 - Vent Pipe (Rubber Hose) - 90342633[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]4 - Equalizer Tank - 90528569[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]5 - Bleeder Valve - 91152226[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]I only want the parts in the yellow circle. Can anyone confirm if the part numbers are correct??[/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]I can't find photos that link to the part numbers of each part.[/color]
#2 FLD
Posted 21 September 2015 - 12:24 PM
Can't help with part nos but could you get a local engineer to make them for you? Might be cheaper that oem! It's the first time I've seen these so could you post dome more details?
#3 thejoaoserra
thejoaoserra
  • 216 posts
Posted 21 September 2015 - 04:26 PM
All the items are cheap. http://www.autovaux....ugscrewm18.aspx I've found this at z22se forum. Link: z22se.co.uk/threads/f23-f25-gearbox-breather-mod.10126/
Edited by thejoaoserra, 21 September 2015 - 04:28 PM.
#4 evocarlos
evocarlos
  • 29 posts
Posted 23 September 2015 - 08:35 PM
https://www.google.c...h&q=gm 90086885
http://www.partsbase...rts/ope-703852/
#5 thejoaoserra
thejoaoserra
  • 216 posts
Posted 23 September 2015 - 09:10 PM
Thank you evocarlos! That second website is very interesting!
#6 Ragged Roy
Ragged Roy
  • 19 posts
  • Interests:VX220, classic Mini, Yamaha R1, Wakeboarding, Kitesurfing, Hairy Pussy/ Maine Coon (cat).
Posted 23 May 2020 - 04:43 AM
When using this kit do you blank off the original breather?
#7 Talk-torque
Talk-torque
  • 150 posts
Posted 23 May 2020 - 01:39 PM
I was just looking at your other post and wondering whether to add my 2P!
What most people do now is fit this kit:
https://www.proalloy...ox-oil-breather
This provides you with all you need to allow the gearbox to breath from the top and return any oil, collected in the top can, to return to the gearbox. Simple to fit and does the job well. I’m sure Type 116 Motorsport on Facebook (chris_uk on here) Would give you a good price.
#8 paul_mck
paul_mck
  • 284 posts
Posted 23 May 2020 - 07:11 PM
where do the 2 pipes attach to?
FWIW I priced the kit in the OP and it comes to £82 ish. For the difference I think Id go pro-alloy
#9 Talk-torque
Talk-torque
  • 150 posts
Posted 25 May 2020 - 10:15 AM
Paul, you can see the original breather stub and the added hose connection adaptor, included in the Proalloy kit, which screws into where the fill plug belongs. An added benefit of the Proalloy setup is that you can use to top can to fill the gearbox.
Gearbox vent connections
Edited by Talk-torque, 25 May 2020 - 10:17 AM.
Also tagged with one or more of these keywords: gearbox, breather, oil, wheel, gearbox breather
