Hesitation With Low Revs After Fitting Larini & Removing Pre-Cat
heistation larini pre-cat
6 replies to this topic
#1 furtive
furtive
  • 1,134 posts
Posted 21 September 2015 - 10:37 AM
I've* fitting a Larini and removed the pre-cat, which sounds great. However, the car now occasionally suffers from hesitation at low revs, for example when approaching a roundabout. It sounds like the car is only running on 3 cylinders for a few seconds and is then fine again.
It's did it once on a short test drive after doing the work on the car, and then twice more when I went on a longer drive.
Any idea what could be causing it?
*I made the tea and made encouraging noises.
#2 fezzasus
Posted 21 September 2015 - 10:41 AM
Car has short term fuel trims which will need adjusting now the exhaust is different (particularly removing pre-cat). I'd keep an eye on it and see if it's there after 100 miles.
#3 furtive
furtive
  • 1,134 posts
Posted 21 September 2015 - 10:46 AM
Ok, thanks. The 70 miles to Snetterton at the weekend is the next time I'll get to try it properly...
#4 slindborg
Posted 21 September 2015 - 11:04 AM
I can chuck about 80 miles on it by going to meetings in Welwyn Garden city this week :lol:
Having read a similar thread on here, it turned out to be a cracked spark plug insulator..
As it seems to only happen at low revs, there must be something particular about the load to cause it. Initially I thought it could have been the EGR valve playing up as it started to misfire when warm, but then didn't happen often enough to be the EGR valve.
#5 furtive
furtive
  • 1,134 posts
Posted 21 September 2015 - 11:44 AM
Thanks for the offer ;)
I'm going to "work" from home on Wednesday so that I can put some miles on it before the weekend
#6 furtive
furtive
  • 1,134 posts
Posted 23 September 2015 - 03:30 PM
This seems to has fixed itself now
#7 slindborg
Posted 23 September 2015 - 05:09 PM
Phew. I hereby declare it's a 300b*hp slinderella stage 1 setup now. *bollocks
Edited by slindborg, 23 September 2015 - 05:11 PM.
Also tagged with one or more of these keywords: heistation, larini, pre-cat
