Saab Engine Oil Consumption
solutions found? list
706 replies to this topic
#241 The Batman
Posted 13 November 2015 - 06:02 PM
I have a 17k engine in my garage :D
#242 The Batman
Posted 13 November 2015 - 09:30 PM
To be honest I imagine all your problems are down to the cat blocking up and causing massive back pressure killing the piston rings etc
#243 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 November 2015 - 11:07 PM
If this was the case then the compression test results would show this.
#244 The Batman
Posted 13 November 2015 - 11:11 PM
What was the compression test results?
#245 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 November 2015 - 11:15 PM
220 on each pistion.
#246 The Batman
Posted 13 November 2015 - 11:17 PM
Oil is escaping somewhere, so if there is no leak then there is a problem with stem seals or piston rings or oil is getting into the intake manifold via the crank breather
#247 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 November 2015 - 11:20 PM
Does 220psi not seem a little high as this would be an indication of excessive carbon buildup in the engine.
#248 The Batman
Posted 14 November 2015 - 12:18 AM
I think he needs to get a leak down test done This will prove the rings are ok
#249 oakmere
oakmere
  • 2,143 posts
Posted 14 November 2015 - 09:04 AM
I think damage to the oil scraper rings can lead to excessive oil consumption but the engine can still have good compression. It is looking more and more that this engine may have to be stripped to assess if any damage has been done 😢
#250 fezzasus
Posted 14 November 2015 - 10:28 AM
Leak testing: There are UV markers you can buy to add to oil, here's an example of one: http://www.amazon.co...l/dp/B00TU9BHN6
You add it, run the engine, look for leaks. At this point we need to go back to basics and confirm the engine isn't leaking anywhere. you may need a black light - depends on the kit.
Question relating to this: Martin, have you taken the under tray off to check for oil patches?
#251 CHILL Gone DUTCH
Posted 14 November 2015 - 10:36 AM
As your flexi is blowing for the third time Martin have you checked that your back box and CAT is in good order As there seems to be a restriction again after the flexi causing it to blow I'm beginning to thing that the previous blockages may of caused significant damage to the engine But there still seems to be more than 1 issue
#252 vocky
Posted 14 November 2015 - 11:03 AM
a borescope would be the simplist option to access the cylinders for any damage caused by the exhaust system failures.
#253 fiveoclock
fiveoclock
  • 9,453 posts
Posted 14 November 2015 - 11:09 AM
I have a usb borescope you can borrow Martin if you want I can post it to you.
#254 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 15 November 2015 - 11:13 AM
hadn't replied sooner as was out al day yesterday but what I do know is that though the software shows fuelling is spot on, the carsmells strongly of fuel in the engine bay of and that's how we found the leak from the flexi joint as there were no bad noises etc.
Will get the flexi joint replaced (luckily theres a really good exhaust maker nearby) as that may be confusing the lambda and the fueling (maybe washing oil away??).
The undertray is totally clean, the catch tank is empty and there back of the car is clean.
I have only posted some of the problems here and am losing patience as this has cost a large chunk of money and resulted in an unreliable worse running car. It genuinely ran a lot better when the ecotec had most of a piston missing!
I keep booking trackdays as incentive to keep at it but after December 12th at Brands I may just put it in the garage and forget it for a few months if it isn't sorted.
Martin S
#255 fiveoclock
fiveoclock
  • 9,453 posts
Posted 15 November 2015 - 11:48 AM
http://www.pistonhea...ng-pack/4836173
#256 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 15 November 2015 - 12:24 PM
strangely just saw that (oh yes, I am looking).
Martin
#257 The Batman
Posted 15 November 2015 - 12:38 PM
I suggest again about getting a leak down test..
#258 fezzasus
Posted 15 November 2015 - 12:59 PM
have you checked the condition of the coolant? It probably can't handle the approx 10 L of oil that have gone into it, but worth checking.
#259 Bargi
Bargi
  • 4,483 posts
Posted 15 November 2015 - 01:33 PM
its brand new engine
#260 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 15 November 2015 - 01:49 PM
Has it developed a fault from being stored or bad fueling in its initial run in or the exhaust issue along with pcv issue which have played off against each other. It may end up needing a rehone and new rings once the exhaust has been proven clear and clean and the pcv fixed or blocked.
