#341
Posted 18 November 2015 - 04:46 PM
#342
Posted 18 November 2015 - 05:08 PM
#343
Posted 18 November 2015 - 05:18 PM
Halfords were doing the GM suitable 5W-30 stuff recently for £12 for 4L... I bought 12L
#344
Posted 18 November 2015 - 05:31 PM
Technically not that cheap. It's the same as Castrol magnatec
#345
Posted 18 November 2015 - 06:01 PM
I have one of these sort of things on the shelf in my garage. Ive not used it other than to have a look down my throat/ears/nose etc 2 years ago. But, if it still works and i remember it (big if) i can bring it to bedford on the 28th.
http://anchortools.c...hp?product=1199
#346
Posted 19 November 2015 - 09:17 AM
ThANks Mark, please bring it as that will be my weekend of doing a few hundred miles and really seeing the state of play as it is now.
I agree oil will make bugger all difference but feel like anythings worth a try.
Martin S
#347
Posted 19 November 2015 - 09:40 AM
Brave you´re hanging in there, and not getting that stupid lotus.
#348
Posted 19 November 2015 - 05:09 PM
Same - Price or the oil itself?
#349
Posted 19 November 2015 - 07:40 PM
the oil
#350
Posted 21 November 2015 - 09:51 PM
Was booked in for a leak down test and they rang to say they could no longer fit me in. Booked in with another garage locally who knew what a leak down test was (most didn't!), went down at 10.30 told me all their ramps were full so could I come back (pointed out it didn't need a ramp to do a leak down test!), went home and they didn't ring.
How can it be so hard to get this stuff done, you'd think I lived in the bloody desert not southern England!
So, no new info. Ho hum.
Martin S
ps Anyone going to Bedford next week who has a Saab conversion. I want to compare dipsticks!
Edited by MartinS, 21 November 2015 - 09:55 PM.
#352
Posted 22 November 2015 - 12:27 AM
Martin S
If you want to be sure of the correct oil quantity and dipstick indication, just drain all the oil and put ~5.5l liter back in.
(The LSJ spec say Oil Capacity - with Filter 5.7L / 6.0 quarts, but the filter cavity does take some oil.)
Edited by Exmantaa, 22 November 2015 - 12:32 AM.
#353
Posted 22 November 2015 - 08:03 AM
I was told the Saab engine takes 7 litres. When we've changed the oil though, its always just been drained and then refilled, using the dipstick to tell us when full rather than measuring in the amount. Just feel its behaving the way a car would if you over fill as is showing no other oil losing characteristics.
Martin S
#354
Posted 22 November 2015 - 09:03 AM
#355
Posted 22 November 2015 - 09:14 AM
Martin S
Complete oil drain down with filter change takes about 7 litres of oil. I've done 6 oil changes on mine now it takes the same amount each time.
#356
Posted 22 November 2015 - 09:31 AM
Complete oil drain down with filter change on Thursday ...6.5 litre .original vx 220 dipstick showing 3 notchComplete oil drain down with filter change takes about 7 litres of oil. I've done 6 oil changes on mine now it takes the same amount each time.
#357
Posted 22 November 2015 - 10:01 AM
you both have the Saab dipstick and Saab dipstick tube, which matches the Saab sump - as GM intended
Which means roughly 6.5 litres per oil change.
It's when you use the vx220 dipstick tube in the B207 engine that it gets over-filled - it requires a good 7 litres per oil change.
#358
Posted 22 November 2015 - 10:08 AM
Martin S
Saab B207 specs (turbo):
9³ SS Technical data
Engine oil
Oil weight: SAE 0W-30
Oil capacity: 6.3 qts (6.0L)
GM-LL-A-025 approved oil only
http://www.saabcentr...ead.php?t=17892
US LSJ specs (=supercharged B207):
2007 Ecotec 2.0L I4 SC ( LSJ )
Type: 2.0L I-4 supercharged
Lubrication System
• Oil Pressure - Minimum - @1000 RPM 344.75-551.60 kPa 50-80 psi
• Oil Capacity - with or without Filter 5.7L 6.0 quarts
http://sixthsphere.c...SJ-engine-specs
I can imagine that a complete dry system in a VX220 with an empty remote oil cooler takes more, but for just refilling the block I would not use more than the above specced 5.7 - 6 liter. (and then check where your dipstick reads)
#359
Posted 22 November 2015 - 10:12 AM
vx220 oil cooler takes approx half a litre from dry
Edited by vocky, 22 November 2015 - 10:13 AM.
#360
Posted 22 November 2015 - 10:36 AM
General Discussion →
VX220 Discussion →
Non Vx Owners ListStarted by Silent Steve , 24 Feb 2014 list |
