Saab Engine Oil Consumption
solutions found? list
706 replies to this topic
#21 Rosssco
Rosssco
  • 4,183 posts
Posted 30 September 2015 - 01:07 PM
A blocked PCV is different to a failed one, one that has failed might be in the open position rather than closed. Meaning the boost from the supercharger could pressurise the crankcase and cause much greater loss of oil than normal.
So perhaps one of the first "tests" for Martin is to remove the intake manifold and block the PCV and check for different levels of oil consumption..
#22 fezzasus
Posted 30 September 2015 - 01:34 PM
also inspect the laminovas
#23 Kieran McC
Kieran McC
  • 3,416 posts
Posted 30 September 2015 - 01:40 PM
My PCV has been blanked of inside the head is was open as most of the LSJ ones are., CS blanked it as they found a few problems with it when on the rolling road for the mapping
#24 smiley
Posted 30 September 2015 - 01:46 PM
PCV is fully supported with the Dutch Software.
(and an aligned pcv hole to the manifold, which the saabs have)
#25 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 30 September 2015 - 01:50 PM
What should be set in the dutch software, in case it hasn't been done.
Martin S
#26 Kieran McC
Kieran McC
  • 3,416 posts
I believe on the CS software the PCV is normally blanked of could be wrong
#27 CHILL Gone DUTCH
Posted 30 September 2015 - 01:58 PM
Just for the record when I put the Saab engine in I switched the pcv valve for the Saab one When blowing down the z22se one and the Saab one there was deffo different restrictions I didn't measure it just by blowing down it I felt the difference in the two
#28 fezzasus
Martin S
No software changes needed.
#29 CHILL Gone DUTCH
Posted 30 September 2015 - 01:59 PM
I mentioned this to Martin on Saturday I'm sure it's on his list of things to check While he cleans his laminovas 🙏🏻
#30 smiley
Posted 30 September 2015 - 02:06 PM
Indeed.
#31 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 30 September 2015 - 02:38 PM
All sound good except I have no idea what to do re regards taking off intake manifolds, checking PCV valves etc, out of my abilities/knowledge zone.
Doing a compression test next (I'm learning stuff all the time, whoopee).  If theres something wrong there, I'll probably just set fire to the car, cook sausages on the heat and sing campfire songs.
Martin S
#32 fezzasus
Posted 30 September 2015 - 02:48 PM
I'd be very surprised if the compression test shows anything
#33 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 30 September 2015 - 03:37 PM
best place to start imo
#34 Nev
Posted 30 September 2015 - 06:32 PM
If you are sure you are genuinely burning the oil, then my guess would be that the rings have not bedded in. If this is the case, resume using a thick mineral oil (ideal with minimal additives) and trash the hell out of the engine for at least 1000 miles. I base my suggestion on having a similar problem (though not as severe) and it improved things for my engine. As additional info, I find my engine consumes more when only lightly driven or cold/warm. When I hammer the engine oil consumption improves, possibly because the rings and pistons expand when really hot. You may get similar symptoms. In the old days people used to shove things like Vim powder into the cylinders to get them scorred up again, but it takes a bold man to do that ! LOL
#35 FLD
Posted 30 September 2015 - 06:36 PM
The build book says to increase the dia of the breather system on boosted engines to at least -12 iirc. This is to slow the speed of the gasses in the crank case vent system which helps the oil vapour condense. Not sure if this is causing your problems, maybe fezzasus has some insight :poke:
#36 FLD
Posted 30 September 2015 - 06:47 PM
One other thought..... Is there a difference in the comb separators in the rocker covers for z22 and Saab?
#37 Kieran McC
Kieran McC
  • 3,416 posts
Posted 30 September 2015 - 07:07 PM
I used mineral for the first few hundred miles to beds the rings in , I'm pretty sure Martin would have done the same .
#38 Sutol
Sutol
  • 8,122 posts
Posted 30 September 2015 - 07:11 PM
Martin was very careful with running in
#39 Nev
Posted 30 September 2015 - 07:25 PM
What does that mean exactly please? I found running in to take around 2000 miles and needed as much revs and power that I could drive with.
Edited by Nev, 30 September 2015 - 07:27 PM.
#40 Kieran McC
Kieran McC
  • 3,416 posts
Posted 30 September 2015 - 07:32 PM
I was told the worst way to run a engine in, was to sit on a motorway at 70 mph not using the revs or using the gears.
