regarding the throttle input issue, have you tried changing the throttle body to a different one?
Posted 25 November 2015 - 01:05 PM
Posted 25 November 2015 - 01:10 PM
MartinS, on 25 Nov 2015 - 07:21 AM, said:
I understand your frustration Martin and as we all know the vx can give you massive headache and not only the engine ๐......... Hope you get it sorted soon and re enjoy the vx Have fitted this b207 in the vx and now fully run ,doesn't use a drop of oil,doesn't smoke and the torque on 4 th and 5 th is pretty insane compare to my old ecotec ..... Another thing I know members on here have always been there to give me good advice and to chin me up Hopefully it will be all sorted soon and chin up as well ,I know it is money and stress but in the end it is a poxy plastic car ......but give us smile ๐ FabI remember it being posted that 'buy these cheap engines' they just bolt in and are better than the ecotec! What a totally load of %$%^&*&*?:~#@#!!!!! ollocks
Posted 25 November 2015 - 02:53 PM
Posted 25 November 2015 - 03:06 PM
Posted 25 November 2015 - 03:41 PM
Or engine build type, are they all 2.0 L?
Posted 25 November 2015 - 03:49 PM
Sutol, on 25 Nov 2015 - 12:39 PM, said:
fezzasus, on 25 Nov 2015 - 11:36 AM, said:
[font="arial, sans-serif;font-size:13px;"]Kaiserslautern, Germany, unless Saab had another manufacturing site (unlikely given they use a shared block)[/font]
OK there wouldn't be a British Leyland scenario when they were going down the pan ie quality control went out of the window??
Plus its not a new engine design that the manufacturing process is not well refined by now, with respects to tooling, assembly processes etc.
Saying that, there's still the possibilty (albeit a small one) of getting a bit of a 'Friday afternoon' engine, despite the process being set-up to remove this.. Not sure how long these engines have been in storage either? I doubt this would be an issue regardless..
Also going back to the PCV system are there fundamental differences between the N/A and blown versions?
Posted 25 November 2015 - 04:09 PM
Sutol, on 25 Nov 2015 - 3:29 PM, said:
No idea I'm afraid. They were kept quiet, I've just heard of them. They were early failures 1000-5000 miles so failed after run in and failed in a similar fashion, not catastrophic just not good.
Posted 25 November 2015 - 04:17 PM
The PCV setup of any passenger car can be described as inadequate at best. Simply put, the ability of a rocker cover weir system to separate oil from gas is pretty poor regardless of design differences. There may be some differences in the pressure needed to activate the PCV check valve in the manifold, however these are just subtleties.
Posted 25 November 2015 - 04:22 PM
If those two people do in fact exist, then they're wnakers for keeping quiet and not making other people with these engines aware of potential problems that might be addressed. Not like they're not going to have got anything other than sympathy or help.
Posted 25 November 2015 - 04:24 PM
Interesting, I would be very curious to know if it's split between 2.2 and 2.0 L versions. Sutol may have a point about the original construction being poor, for example, I have seen sizing issues with pistons used for industry standard testing. Some pistons have been too big to actually fit in the bore from the same supplier as previous batches.
Posted 25 November 2015 - 04:27 PM
Posted 25 November 2015 - 04:41 PM
Posted 25 November 2015 - 04:43 PM
Edited by CHILL Gone DUTCH, 25 November 2015 - 04:44 PM.
Posted 25 November 2015 - 04:44 PM
Posted 25 November 2015 - 04:47 PM
Or there is no inherent problem and it's isolated to Martin's engine in particular.
/still_patting_the_real_B207R_engine_in_the_garage
Posted 25 November 2015 - 04:48 PM
General Discussion โ
VX220 Discussion โ
Non Vx Owners ListStarted by Silent Steve , 24 Feb 2014 ![]() |
