^OEM saab/GM (Mahle) pistons with OEM piston gap...
#521
Posted 19 December 2015 - 11:10 AM
#522
Posted 20 December 2015 - 12:30 AM
Getting there now.
#523
Posted 20 December 2015 - 01:28 PM
#524
Posted 20 December 2015 - 01:29 PM
#525
#526
Posted 20 December 2015 - 01:56 PM
cylinder head
#527
Posted 20 December 2015 - 02:30 PM
#528
Posted 20 December 2015 - 02:33 PM
#529
Posted 20 December 2015 - 04:01 PM
#530
Posted 20 December 2015 - 04:32 PM
Not helped by ridiculous intake temps (95deg on the road in the cold and rain).
#531
Posted 20 December 2015 - 04:37 PM
95 is harrop on track territory.
Maybe the laminova's are clogged up?
#532
Posted 20 December 2015 - 04:42 PM
Maybe the laminova's are clogged up with the missing oil?
#533
Posted 20 December 2015 - 05:17 PM
They said his chargecooler pump was not working well, but his earlier logs do not show these excessive temperatures (50-60°C on road), so this is probably a problem that has worsened in the last weeks.
Curious to what the RR mapping session brings and if the leaned out AFR's will do anything for his oil consumption.
Edited by Exmantaa, 20 December 2015 - 05:20 PM.
#534
Posted 20 December 2015 - 08:11 PM
Yes cc pump looks to be the issue as the temps took a long time to recover as well. However if you just datalogged one rpm sweep then temps would probably look ok.
#535
Posted 20 December 2015 - 09:06 PM
The logs I speak of were of some road driving in Sept / Oct; showing peaks and recovery temps of the chargecooler system.
#536
Posted 20 December 2015 - 09:29 PM
Getting there now.
Are you likely to give martin a Christmas present with his car being sorted?
#537
Posted 20 December 2015 - 09:42 PM
#538
Posted 20 December 2015 - 10:24 PM
#539
Posted 20 December 2015 - 11:06 PM
#540
Posted 21 December 2015 - 11:22 AM
General Discussion →
VX220 Discussion →
Non Vx Owners ListStarted by Silent Steve , 24 Feb 2014 ![]() |
