Saab Engine Oil Consumption
solutions found? list
706 replies to this topic
#561 Matthew Bentley Racing Ltd
  • 774 posts
Posted 23 December 2015 - 08:18 PM
I forget to say to Martin in the email, but me and Lee both think the drop in power at the top is probably the 2.25" exhaust system. No point reving past 7k.
#562 Matthew Bentley Racing Ltd
  • 774 posts
Posted 23 December 2015 - 08:19 PM
Yes melted cat. Completely blocked.
I don't know about more, the ignition is just mapped to peak torque now so will have a bit more over std maps.
#563 CHILL Gone DUTCH
Posted 23 December 2015 - 08:29 PM
did you manage to get a comparison run matt so we can see how accurate the obdtuner runs are in comparison with the dyno
#564 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 23 December 2015 - 08:30 PM
Makes sense for the symptoms but it'll be interesting to know the exhaust woes start to finish as wasn't that checked and replaced a few times :/
#565 smiley
Posted 23 December 2015 - 08:39 PM
The one that was in when it arrived at your workshop?
#566 CHILL Gone DUTCH
Posted 23 December 2015 - 08:46 PM
bit of background with exhaust
martin had it repaired before zandvoort (flexi issues) but was by the time we got to zandvoort the flexi had gone again
all this was on first down pipe
we then swapped down pipe at zandvoort for one from frank
the track day went resonably well but the car was not mapped, maybe just a fuel run from the previous down pipe (unsure of condition )
martin was not 100% happy with the car at zandvoort but considering the issues before he did very well
after getting home thats when the inlet pressures started to increase and the power went down so this was probably the start of the blocked cat.
at this point the exhaust was passed as ok but we suspect not
Edited by CHILL Gone DUTCH, 23 December 2015 - 08:50 PM.
#567 Zoobeef
Zoobeef
  • 11,103 posts
Posted 23 December 2015 - 08:53 PM
So, are we thinking a bad map from a leaking exhaust melted the new cat as the leak was then fixed? Hopefully this has sorted out the oil issue too. Bad for the oil industry though as I'm pretty sure Martin was keeping Shell in business.
#568 Matthew Bentley Racing Ltd
  • 774 posts
Posted 23 December 2015 - 09:15 PM
Yes the one that was on the car when it arrived with me and Lee. No comparison. Don't even know how to do one lol. Just mapped it. Martin can do it and post up.
#569 CHILL Gone DUTCH
Posted 23 December 2015 - 09:26 PM
Martin did plenty of fuel learn sessions and the fuel trims looked ok but llambda could of been damaged or anything
its also a good idea to have a wideband installed for martins specs
#570 Matthew Bentley Racing Ltd
  • 774 posts
Posted 23 December 2015 - 09:42 PM
Martin did plenty of fuel learn sessions and the fuel trims looked ok but llambda could of been damaged or anything    its also a good idea to have a wideband installed for martins specs
Lack of wideband made it hard to map low speed exhaust gas flow fueling.
#571 CHILL Gone DUTCH
Posted 23 December 2015 - 09:51 PM
also if the exhaust is damaged in any way or form the lambdas cant do there job correctly so the mapping is never going to be right
#572 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 23 December 2015 - 10:07 PM
Right pics of the cat
#573 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 24 December 2015 - 10:37 AM
Thats gotta be around 300BHP  ... Martins Lotus Evora order will need to be cancelled   :P
#574 CocoPops
CocoPops
  • 17,181 posts
Posted 24 December 2015 - 10:42 AM
Dutch software says 500bhp
#575 CHILL Gone DUTCH
Posted 24 December 2015 - 10:44 AM
Dyno power = 260bhp at wheels. Dutch Software = 350bhp at crank. Tongue in cheek guesses before anyone gets arsy :lol:
#576 CHILL Gone DUTCH
#577 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 24 December 2015 - 10:51 AM
I used this....for a guide
http://www.mk5cortin...calculator4.php
#578 smiley
Posted 24 December 2015 - 11:16 AM
As much as i like all the willy waving on hp, i'm still slightly worried on the piston rings, with the decission not to open up the engine and look.
#579 Exmantaa
Posted 24 December 2015 - 11:27 AM
We found ~17% drivetrain loss gave us comparable numbers, but depends on the rolling road calibration and also on rear tire spec & allignement...
Well, at least now Martin's high boost, heat and bad running issues are remedied with this dead cat issue (I think this exhaust was inspected and given the "ok" 2 or 3 times since the start of his problems :unsure:) and that curve looks very driveable.
But some isssues he started with are still there; the steep power drop after 6800rpm and still waiting on how the oil usage is now.
I hope that last one was initially caused by the pcv valve leak and after fixing that the exhaust blokkage played up. (that cat section looks very white inside. Ash from burned oil?)
Powerdrop after 6800rpm is still a bit of a mystery. Power leveling off or slightly drop I would suspect a restrictive exhaust section, but not this steep drop in power and torque.
(And that same 2.25 downpipe, still including the cat section, was used on a Harrop 2.0 that had no trouble hitting the rev limiter @ 7700rpm. :rolleyes:)
#580 Matthew Bentley Racing Ltd
  • 774 posts
Posted 24 December 2015 - 11:48 AM
[quote name="Exmantaa" post="1835428" timestamp="145095642
(And that same 2.25 downpipe, still including the cat section, was used on a Harrop 2.0 that had no trouble hitting the rev limiter @ 7700rpm. :rolleyes:)[/quote]
Yes strange drop off that fast. New I wasn't going to be able to save it. Either this it's the exhaust or maby worth Vocky moving the inlet cam.
Gives a mega Road engine though.
