Saab Engine Oil Consumption
solutions found? list
706 replies to this topic
#141 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 October 2015 - 07:39 AM
What's your rev limit on the car Martin?
#142 vocky
Posted 11 October 2015 - 08:31 AM
also worth mentioning that the vx220 dash rev counter stops dead at 7000rpm, so how are you working out the max rpm of the engine ?
#143 CHILL Gone DUTCH
Posted 11 October 2015 - 11:09 AM
Unsure what my inlet temps were I'm afraid, but something is stopping my engine hard at 7000, so even if I have a weird mix of oil and fuel going (people who followed me said my car really smelt fuelly)of fuel and oil) it wouldnt be that hard a stop, so think mine must be ignition related as it behaves like a rev limiter.   Martin S (Am right out of my depth in these conversations now!!!)
It's not just heat which pulls ignition back It's also knock Up to you Martin but I was not convinced you got the knock the learn mode in to the ecu Artic monkeys (Harrop) ran a lot better yesterday in cooker differences but we did make some minor adjustments Lowered the rpm ( we did this due to blow by on his small pulley the piston rings are not so good when things are hot ) static compression test would not show this , this is also linked to the combustion chamber temps, amount of boost and any other restriction. We also used she'll optimax and used lower gapped plugs and lower temp number to cope with higher temps The temp range I think has been overlooked a lot But she'll IMO is a lot better fuel for temp control These are minor things but when brought together make large gains Which makes a bit of sense if you are getting raw fuel out of the rear of the car
Edited by CHILL Gone DUTCH, 11 October 2015 - 11:10 AM.
#144 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 October 2015 - 02:32 PM
I also think my knock learn session applied to the map has made a very big difference. Maybe that's what was creating the rush of heat and putting the temps up quick.
#145 CHILL Gone DUTCH
Posted 11 October 2015 - 03:14 PM
I actual thing the BiGGesT difference was the cooler temps outside
#146 Exmantaa
Posted 11 October 2015 - 04:14 PM
The problem with the dropping BHP at high rpms show clearly in his OBD power logs...
#147 Bargi
Bargi
  • 4,483 posts
Posted 11 October 2015 - 04:45 PM
And it's not the ECU backing off power because of IATs?
#148 Exmantaa
Posted 11 October 2015 - 06:44 PM
For sure Martin does not mind posting a pic of his problem:
OBD Tuner powerrun, showing a sharp torque and power drop from 7K onwards to the rev limiter.
Boostpressure stays fairly flat; ~200KPa (although a bit highish for an M62)
Ignition also steady up top with ~17-18 degrees.
This log does however show about 3 degrees knock retard from 5K on.... Maybe that causes some internal ecu function that limits power up top? (=> retard ignition map a bit from 5K onwards)
Edited by Exmantaa, 11 October 2015 - 06:47 PM.
#149 siztenboots
  • 26,613 posts
Posted 11 October 2015 - 07:02 PM
remove air filter and try again
#150 Matthew Bentley Racing Ltd
  • 774 posts
Posted 11 October 2015 - 07:04 PM
Iat?
#151 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 October 2015 - 07:08 PM
Iat?
51.5 and 54.9 it says in the left hand table.
#152 CHILL Gone DUTCH
Posted 11 October 2015 - 07:14 PM
I would imagine if there was constant WOT IAT would be higher @ 60 degrees there will be retardation
#153 Matthew Bentley Racing Ltd
  • 774 posts
Posted 11 October 2015 - 07:20 PM
That reading temp from the inlet manifold yeah?
#154 The Batman
Posted 11 October 2015 - 07:21 PM
Yeah
#155 ArticMonkey
ArticMonkey
  • 4,792 posts
Yep from the Tmap.
#156 Exmantaa
Posted 11 October 2015 - 07:36 PM
Was one of my thought too and Martin said he changed that out for his old cone filter and tried another run (also with different plugs) with the same result.
Still no guarantee that his filter is not restrictive, but his boost pressure (MAP) is constant up top and that should show a drop if there was an inlet restriction.
Same with excessive exhaust pressure; that normally show a rise in MAP pressure. (We once saw 258KPa MAP with a blocked Tullettt cat on our Harrop... :happy: )
Edited by Exmantaa, 11 October 2015 - 07:43 PM.
#157 The Batman
Posted 11 October 2015 - 07:37 PM
Knowing Martin he probably has a gearbox breather as a air filter :lol:
#158 Matthew Bentley Racing Ltd
  • 774 posts
Posted 11 October 2015 - 08:05 PM
I think 54 deg is optimistic. I think that is probably from a single run after the system temps have dropped. I think after 3-4 gear changes that would be higher. A data run from a track session or few pulls on the dyno would be better.
#159 Exmantaa
Posted 11 October 2015 - 08:28 PM
It is optimistic and from a single run, but not the source of his poblem now; the power drop @ 7K.
And that was with those measured IAT's. (Although the TMAP is a bit slow at measuring air temps...)
#160 The Batman
Posted 11 October 2015 - 08:31 PM
if it was a restriction like exhaust or intake, shouldnt it maintain the same power from 7k to 7.5k?
as that drops of then surely its a mechanical/ecu problem
