Good progress... Althought you're going a bit JG with the bracket painting and stuff
Daryl's Plastic Box Of Joy
#61
Posted 01 December 2015 - 11:43 AM
#62
Posted 01 December 2015 - 02:57 PM
Thanks. Any way of telling if I have standard ones or lowered ones? Judging by the state of them, id guess they are standard.These are already plated. I did them when I refreshed my suspension but I now have nitron mounts. The ABS side one is new, never used but it's one from Gaz not an OEM one. I'll look them out. If you don't hear anything pester me as I'll have forgotten. ETA: new oem ones are about 16 quid a side and come plated if I can't find them.
#63
Posted 01 December 2015 - 03:03 PM
This is the drivers side rear lower wishbone area, from behind the car. The bolts hold the bracket in place for the tie rod.
This is the passenger side, admittedly iv removed the bolt. And there is the clue
Not seen it? The passenger side bracket was only held in by one screw/bolt, where as the drivers one has 3. Surely this is not normal!
Also managed to get the heater diverter duct out, in several pieces. So will be cleaning this all up, and sealing everything to help the heater situation.
#64
Posted 01 December 2015 - 03:05 PM
Im guessing you mean a little OTT with the painting? I hate things looking shabby, especially when they can be pulled off and put back easily. Iv removed the ABS mounting bracket also, and will be painting that up at some point. Ok, maybe its getting a little obsessive....Good progress... Althought you're going a bit JG with the bracket painting and stuff
#65
Posted 01 December 2015 - 03:58 PM
ABS mounting bracket is also fairly cheap new and comes plated. I know this because I have a new one to go on. I'm of the same mind as you.
#66
Posted 01 December 2015 - 04:12 PM
Not at all.. Its just because I drive a Scottish VX where there's little point in making things look nice
#67
Posted 01 December 2015 - 04:16 PM
The AV mounts for the chassis are not though! Best part of £10 each! Does the bracket come with the AV locators fitted? These pop inside the bracket. The £10 ones are the ones that mount the bracket to the chassis.ABS mounting bracket is also fairly cheap new and comes plated. I know this because I have a new one to go on. I'm of the same mind as you.
#68
Posted 01 December 2015 - 04:17 PM
It is becoming a little obsessive, but it should all look good at the end, if it all goes back together.Not at all.. Its just because I drive a Scottish VX where there's little point in making things look nice
#69
Posted 02 December 2015 - 08:31 AM
Someone found a cheap source on here recently, might be worth a search. I bought new from lotus and paid the premium
#70
Posted 02 December 2015 - 12:39 PM
#71
Posted 03 December 2015 - 10:40 PM
Got the shearplate off, and cleaned that up, didnt come up too bad.
Also, removed the brackets that the FWD leg of the RLWB and the handbrake cable bolts to. Couple of the bolts were a little awkward as black cylinder,(charge cooler?) was mostly in the way. All off and painted silver now. Though i may paint them black to match other bits on the car. Cant decide if the silver is too bling.
Edited by D-DAWG83, 03 December 2015 - 10:41 PM.
#72
Posted 03 December 2015 - 11:06 PM
#73
Posted 04 December 2015 - 12:16 AM
#74
Posted 04 December 2015 - 12:25 AM
Oil coolerblack cylinder,(charge cooler?)
#75
Posted 04 December 2015 - 12:35 AM
That's the one, excuse my ignorance, of course the charge cooler is at the front. Long day, and some alcohol consumedOil coolerblack cylinder,(charge cooler?)
#76
Posted 07 December 2015 - 02:55 PM
As i was never intending to replace the tank this year, id left a rather large amount of fuel in the car, over half a tank, which id forgotten about, so that added some 'excitement'
#77
Posted 17 December 2015 - 10:43 AM
Loving the improvised fuel capon the old tank!
#78
Posted 17 December 2015 - 12:00 PM
#79
Posted 17 December 2015 - 02:06 PM
Christmas Break Dude we can spend a day on it!
#80
Posted 20 December 2015 - 06:30 PM
Small update, the new tank is in, and all wired up and plumbed in. Just need some fuel in it at some point. Going to start putting things back together soon. Got some mesh to cover the intakes in the crash box, and i need to seal up a new (to me) heater from Vocky. Also got some more bits to order, like the diverter panel for the heater, which was busted on mine.
