Yep, did that this morning, as im limited what i can do at 6am in the garage. LolBit of Satin paint over that and will look fine mate. Coming on nicely now.. See you on Monday..
Daryl's Plastic Box Of Joy
#101
Posted 18 March 2016 - 01:17 PM
#102
Posted 18 March 2016 - 01:18 PM
#103
Posted 18 March 2016 - 01:43 PM
Ikea..... lol
#104
Posted 26 March 2016 - 09:09 PM
With all them in place, i started to fit up the heating system, as id stripped and rebuilt both the heater box, and the diverter box from both my original, and other ones id bought.
Found out 3" tube dont fit the heater pipe, so ordered 80mm, and that fits a treat. Fitting the dampers proved a pig of a job also, and as it turns out, requires gently manipulation of the mouting areas to increase the width enough to squeeze them in. Some of the top hats had seen better days, so i made them as good as i could.
Also relocated the ECU, twice. Id assumed (wrongly) that the J1/J2 faced the right way up, and i didnt measure the hole centres before drilling. So after id done it once, i found one of the plugs would not reach, so had to take it all apart, and start from scratch. Looks good now though.
Replaced the inner most rubber seals on the rear calipers as well, as they were not in the best of condition.
Fitted new foam to where the ducts for the heater go as well.
Worked out a way to bolt the rear hub up without the HCB block.
#105
Posted 26 March 2016 - 09:17 PM
Too much shiney shiney, it's hurst my eyeses !
#106
Posted 26 March 2016 - 09:20 PM
Both fronts are now ready for wheels.
Refitted the battery and put some new foam on the bracket that holds it in, thought i may as well, though it will probably get replaced next strip, as its corroded quite badly where water has sat, cleaned up and soaked in ACF50, but a nice shiny one would look good.
Refitted the wiper motor aslo, and got bored of dropping bits into the front abis, so stuffed a load of rags in there to catch anything wanting to escape.
#107
Posted 26 March 2016 - 09:34 PM
There is a rusty caliper there if you are offended by the shiny stuffToo much shiney shiney, it's hurst my eyeses !
#109
Posted 26 March 2016 - 10:20 PM
#110
Posted 27 March 2016 - 06:25 AM
#111
Posted 28 March 2016 - 07:39 PM
Charge cooler pipes
Main system
#112
Posted 30 March 2016 - 09:14 PM
Had some shiny carbon shims made for the rear clam support
And here she is being filled up by the attendant.
#113
Posted 31 March 2016 - 10:14 AM
Well done bud, epic work to get her on the road!! Looking fwd to Monday?
#114
Posted 31 March 2016 - 12:42 PM
Congrats Daryl! Looks great. I thought carbon fibre against steel was a corrosion no-no though?
#115
Posted 31 March 2016 - 05:40 PM
#116
Posted 31 March 2016 - 05:47 PM
Turns out to be an S2 part, not the S1 one like it should be. So now frantically searching for a wishbone...
That doesn't sound right. Pretty sure the VX and S2 Elise wishbones are common parts, other than the lower rear divers side for turbos. Most of the Eliseparts wishbones I ordered last year were labelled as S2.
S1 Elise and Exige have completely different wheel offsets, so the wishbones are different lengths from the VX/S2 Elise.
#117
Posted 31 March 2016 - 06:13 PM
#118
Posted 05 April 2016 - 02:36 PM
#119
Posted 05 April 2016 - 06:08 PM
Jeeze, sounds like you warped space time to get that lot done and get it to the track day !
#120
Posted 05 April 2016 - 07:25 PM
