Track Spring Rates
#301
Posted 23 November 2015 - 10:55 PM
#302
Posted 23 November 2015 - 11:01 PM
Matthew Bentley Racing Ltd, on 07 Oct 2015 - 10:16 PM, said:
Sticking with your current dampers I would go for 650lb rears with 275 or 300lb helpers, and 500lb fronts with 200 or 250lb helpers (I will ask Nitron tomorrow what the lb limit is on street series) Other option is a set of single way Quantums or the new 'NTR40 Clubsport' dampers I am developing with Nitron. Actually going to be looking to test the dampers on a couple of cars very soon..............
Scuffers, on 21 Nov 2015 - 12:51 PM, said:
Seems like we have a winner in terms of target rates. I was hoping to stick with the NSS for now but the valving won't go that far (max is maybe 550lb-600lb). With helpers and collars the springs alone are close to £350 though which would be a fair way towards quantums/clubsport NTR. Hmmmm decisions... I might just go linear 425/550 for now as a stop gapif it was me, knowing how you drive, I would go with 500/650 (with 200/300 tenders) on Quantum single ways, along with a 1" ARB. Longer term, springs are cheap, and if you progress, then it's cheap/easy enough to switch them out for stiffer later..
Edited by Captain Vimes, 23 November 2015 - 11:04 PM.
#303
Posted 23 November 2015 - 11:11 PM
#304
Posted 23 November 2015 - 11:35 PM
425 / 550 needs at least helper (tender? the things with some lbs) springs on the rears.
And as the NSS fronts are a bit longer than NTRs, you probably need helpers there too. Assuming you don't want to ride that high...(Fit owering brackets up front)
#305
Posted 24 November 2015 - 12:13 AM
#306
Posted 19 December 2015 - 11:49 AM
I think the street series are a bit narrower than the ntr version. Found this that says the piston diameter in the street series is 38mm and on the ntr40 is 40mm http://www.lir-racin...eaux NITRON.pdf
