ohlins are metric sizing , you can get spring perch adaptors that allow you to use more common 2.25" springs
thats assuming you have the 36mm damper
Posted 12 October 2015 - 09:10 AM
Posted 12 October 2015 - 09:12 AM
Yep 1.9" O/D but the springs on them are a unique size as I've tried a few places and no one does the spring length and width together. Looks like Ohlins made did this for a reason so they can't be changed with other brands.
Yours are the 1.9" ID ? Faulkener springs are very limited in choice at that ID. Max 400 or 450 I believe. Also if you want Faulkener springs just go to them direct.
Where you finding these cheap springs from? Best I can find so far is £80 plus vat per spring for the Ohlins 😢Springs are cheap so just buy some and test for yourself, everyone likes different things
what are you lot on about?
1.9" is a std spring size, as is 2.25", just about everybody makes/uses one or the other.
Faulkners are not a manufacturer, they have their springs made for them but using their spec's, materials, etc, they can make whatever you ask for (within limits!).
they stock a huge range of std linear springs, I have yet to catch them out with a specific spring not being on the shelf.
Typically they stock anything from ~4-16" long in 2.25" and 1.9" usually in 25 or 50Lb increments.
problem with 1.9" is that there are limits to what can be made, that said, you can make 500+lb ones, just no real demand as anything that heavy will use 2.25" as the damper to support it will need to be somewhat bigger than what fit's in a 19" spring.
Posted 12 October 2015 - 09:13 AM
I can't go 2.25" as its to big for my setup and will catch on my Cv boot.ohlins are metric sizing , you can get spring perch adaptors that allow you to use more common 2.25" springs
Posted 12 October 2015 - 09:16 AM
I'm afraid to ask WTF have you done... (and WHY???)
Falkners do stock high rate 2" if that helps?
Posted 12 October 2015 - 09:19 AM
Posted 12 October 2015 - 10:13 AM
Posted 12 October 2015 - 10:30 AM
Basically he shortened his wheelbase because he has bought new clothing 1 size too small...
Posted 12 October 2015 - 12:50 PM
Hang on, I remember something about some bodge rear ARB setup?
Posted 12 October 2015 - 01:14 PM
Can't wait for someone to tell him
Posted 12 October 2015 - 01:26 PM
Go on Haggi; spill the beans.
Tell Mr Scuffers what you did
Posted 12 October 2015 - 01:34 PM
Posted 12 October 2015 - 01:53 PM
😀 the vx is running 900bhp so custom drive shafts have been made😃
?? are they 2.25" thick or something?
Really?
Posted 12 October 2015 - 02:02 PM
Posted 12 October 2015 - 02:03 PM
Show Mr Scuffers a picture Haggi
Posted 12 October 2015 - 02:23 PM
R e a d better...
Posted 12 October 2015 - 02:33 PM
OK, I guess we are talking about this bodge:
though I am not sure why this affects the dampers clearances?
Posted 12 October 2015 - 02:40 PM
Try again......lol
Posted 12 October 2015 - 02:58 PM
Posted 12 October 2015 - 03:07 PM
Try again......lol
CBA,
if you have something to say, F**king say it.
Posted 12 October 2015 - 03:12 PM
http://www.vx220.org...project/page-26
his thread is here, something along the lines of vx220 turnt into a s2 exige but rear wishbones needed cutting and rewelding to avoid body blah blah blah
