Brake Servo Vacuum Hose
9 replies to this topic
#1 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 14 October 2015 - 09:03 AM
I'm guessing the Europa has the same hose as the VXT?
Can anyone confirm before I ring podge to order one?
No 39 in the pic http://www.deroure.c...&SMO=0&ST=&SC=0
#2 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 14 October 2015 - 09:12 AM
Yep it's number 39 but I would buy off eBay as that's expensive for the price you could get it.
Edited by haggi961, 14 October 2015 - 09:12 AM.
#3 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 14 October 2015 - 09:20 AM
I was thinking of getting an OEM part because it seems to have the 90 deg elbow, which I also need.
I suppose I could go for a silicone vacuum pipe off ebay and try to source the elbow separately. I'm not sure the silicone hoses are up to the job though and might collapse
Do you know the correct ID (and OD)?
Edited by Gedi, 14 October 2015 - 09:33 AM.
#4 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 14 October 2015 - 09:44 AM
I've had a look around and that price actually seems okay (plus podge is normally ~10% cheaper than deroure)
It's £30 from cbsonline
#5 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 15 October 2015 - 07:34 PM
Has anyone on the forum tried using a silicone vacuum hose?
Are they strong enough or are they likley to collapse?
http://www.ebay.co.u...8_xYA9WfjA76yLw
#6 slindborg
Posted 15 October 2015 - 07:45 PM
I wouldn't trust silicon hose for that length of run. I used some vacuum hose from the ebay seller that used to do the heater pipe work kits on here, was circa £20, so for the oem part its not much in it
#7 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 04 November 2015 - 01:02 PM
Forgot to reply back to this. This stuff should be fine as its 10mm I/D and a couple of meters should be enough. Should be a lot cheaper then buying from lotus or Vauxhall http://pages.ebay.co...lobalID=EBAY-GB
#8 AustinB
AustinB
  • 256 posts
  • Interests:Motorsports, Baseball, Running
Posted 10 May 2016 - 12:11 PM
I've had a look at the related threads, but I can't seem to see how long this hose should be. I was thinking of ordering 4-ish meters to be sure I have enough?
#9 JdoubleU
JdoubleU
  • 71 posts
Posted 10 May 2016 - 09:22 PM
Yep 4 metre did mine fine.
#10 AustinB
AustinB
  • 256 posts
Posted 11 May 2016 - 08:42 AM
Cheers, thanks! :)
