Nitron Street Series Group Buy
nitron street series group buy
307 replies to this topic
#181 TFD
TFD
  • 607 posts
Posted 17 December 2015 - 11:06 PM
I've just finished installing mine. To get the front at 120mm I had to wind on a tiny amount of preload on the springs. To get the rear as high as 130mm I had to put a LOT of preload on. Something like 13 full turns of the collar to the point that there isn't much thread left on the damper body. Is this going to be a problem?
So minimum pre-load will allready result in a lower front height, correct? Want to lower to max 15mm at the front.
Will get my car on a platform bridge for the best meassurements when putting them on.
#182 Matthew Bentley Racing Ltd
  • 774 posts
Posted 17 December 2015 - 11:28 PM
13 turns is what it is. If that's what is needed that's what you have to have. Doesn't sound crazy to me
#183 DaveyC
DaveyC
  • 259 posts
Posted 18 December 2015 - 08:31 AM
thumbsup
#184 DaveyC
DaveyC
  • 259 posts
Posted 18 December 2015 - 08:33 AM
Yes, that's right.
For the fronts I loosened the collars until the spring could just move a tiny bit, then tightened them one turn. Once on the car I only needed another turn each side to get the car to 120mm (with 16" front wheels).
#185 stu8v
stu8v
  • 745 posts
Posted 18 December 2015 - 09:06 AM
  So minimum pre-load will allready result in a lower front height, correct? Want to lower to max 15mm at the front. Will get my car on a platform bridge for the best meassurements when putting them on.
Yes, that's right.   For the fronts I loosened the collars until the spring could just move a tiny bit, then tightened them one turn. Once on the car I only needed another turn each side to get the car to 120mm (with 16" front wheels).
You got a piccy of how it looks now?
#186 BigD
BigD
  • 16 posts
Posted 18 December 2015 - 09:46 AM
Davey did you have ballast in the car too?
#187 DaveyC
DaveyC
  • 259 posts
Posted 18 December 2015 - 09:49 AM
No pics yet. Will try and get one later. I stuck a load of garage equipment and some water containers in there to act as ballast.
#188 BigD
BigD
  • 16 posts
Posted 18 December 2015 - 11:07 AM
So in summary, mainly for me. :happy:
More pre-load will raise the car less to lower. Obvious.
Front - Minimal preload will already give 120mm - so if you want to go lower there will be no preload - in other words you can't really go any lower? (Not complaining but just clarifying in my head, these are the street series so not designed for full on trackwork, understandable that they would work on standard ride heights) :happy:
Rear - Needs a lot of preload to get 130mm (13 turns ish) - so plenty of scope to go lower.
#189 stu8v
stu8v
  • 745 posts
Posted 18 December 2015 - 01:03 PM
Bolt just turned up here.
#190 DaveyC
DaveyC
  • 259 posts
Posted 18 December 2015 - 01:52 PM
So in summary, mainly for me. :happy:   More pre-load will raise the car less to lower. Obvious.   Front - Minimal preload will already give 120mm - so if you want to go lower there will be no preload - in other words you can't really go any lower? (Not complaining but just clarifying in my head, these are the street series so not designed for full on trackwork, understandable that they would work on standard ride heights) :happy:   Rear - Needs a lot of preload to get 130mm (13 turns ish) - so plenty of scope to go lower.
Yep. That's right in my case.
#191 Haston
Haston
  • 198 posts
Posted 18 December 2015 - 02:06 PM
I'm going to set it till the spring is just held then go up or down from there.
#192 dylan390
dylan390
  • 166 posts
Posted 19 December 2015 - 08:52 AM
I have never quite figured how the spring seats don't unscrew if there is nil preload.
#193 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 19 December 2015 - 11:23 AM
My NSS were originally set with loose springs (previous owner) to get to 123/115 height. They never unscrewed themselves. I guess the number of times the spring would become unloaded is very small and even then there's no reason for the collar to spin, especially once the threads are covered in road grime..
#194 export001
export001
  • 116 posts
  • Interests:If you call constantly breaking the vx then yes
Posted 19 December 2015 - 11:52 AM
my bolt arrived yesterday woo
#195 BigD
BigD
  • 16 posts
Posted 19 December 2015 - 11:53 AM
That's good to know as that's roughly where I wanted mine to be.
#196 TFD
TFD
  • 607 posts
Posted 19 December 2015 - 02:56 PM
To get things correct: The more preload, the higher the rideheight?
I.o.w.: More preload pushes the shock more out hence the higher ride?
#197 ciderbooze
ciderbooze
  • 1,222 posts
Posted 19 December 2015 - 05:39 PM
My bolt has arrived, all ready to go. As the brackets are painted I assume this negates the need for duralac?
#198 stu8v
stu8v
  • 745 posts
Posted 19 December 2015 - 09:25 PM
How close are they shocks to the top suspension arm? I think I will have to look at maybe increasing the caster to gain clearance.
#199 thejoaoserra
thejoaoserra
  • 216 posts
Posted 20 December 2015 - 02:16 AM
Put duralac between the chassis and brackets surfaces. Can't hurt and some paint can't inhibit corrosion between two different materials (galvanic corrosion). And that way water won't get in between chassis and bracket surfaces.
#200 thejoaoserra
thejoaoserra
  • 216 posts
Posted 20 December 2015 - 02:21 AM
Do you know what and how are the handling characteristics affected by caster? Is bump steer one of them?
Edited by thejoaoserra, 20 December 2015 - 02:24 AM.
Also tagged with one or more of these keywords: nitron, street series, group buy
