Edited by BigD, 28 December 2015 - 10:48 AM.
Nitron Street Series Group Buy
#221
Posted 28 December 2015 - 10:48 AM
#222
Posted 28 December 2015 - 10:54 AM
#223
Posted 28 December 2015 - 01:24 PM
http://www.vx220.org...-street-series/
I currently use 10 from hard front 12 from hard rear as recommended by the person who did my Geo. As per the thread above, this is way too hard. I am going to try something different and go for 10 from soft front and 14 from soft rear.
Edited by Ormes, 28 December 2015 - 01:24 PM.
#224
Posted 28 December 2015 - 04:22 PM
#225
Posted 28 December 2015 - 04:46 PM
I think 12 front and 14 rear on track will probably be about right (always from full hard) and many 14 and 16 or 16 and 18 on the road.
#226
Posted 28 December 2015 - 09:05 PM
#227
Posted 29 December 2015 - 01:01 AM
#228
Posted 29 December 2015 - 01:48 PM
#229
Posted 21 January 2016 - 03:54 PM
#230
Posted 21 January 2016 - 04:23 PM
#231
Posted 21 January 2016 - 05:07 PM
Would these
http://www.ebay.co.u...=STRK:MEBIDX:IT
plus these
do? I know they are low weight springs but they only have to take up slack when unweighted.
#232
Posted 21 January 2016 - 06:14 PM
I've asked nitron what would the best solution be for the loose spring problem when lowering the car. "We can fit longer springs to combat this but these will need to be charged at £55+ VAT each."
When asking the same question of them a few years ago i was told I needed to buy helpers + shorter springs at over £700!... which is more than I paid for them in the first place...
My springs are still not loaded when jacked up, but not so much that they are beneath the base of the collar.
#233
Posted 22 January 2016 - 01:04 PM
My vx is 148mm all around when complete OEM. Fitted the nitrons and after adjustment this morning front is now 141mm with just 2 turns from lose spring.
Maybe it will drop till 140mm tomorrow after bedding in over night but cant see this drop down to (148- 20mm) 128mm...
#234
Posted 22 January 2016 - 09:57 PM
I don't understand how longer springs would help. Surely if needs helper/tender springs?
If you have a longer spring you can pre load the spring at a bigger distance from the spring seat to the spring adjusting collar.
I'll ask nitron if a 1 in longer spring would allow us to set the car to OEM ride height (140mm) without putting to much preload on the spring to avoid damaging the damper.
#235
Posted 23 January 2016 - 11:18 AM
#236
Posted 23 January 2016 - 12:42 PM
My understanding is this.. A longer spring will just change the point at which the collar sits on the shock body. For a given preloaded amount and (linear) spring rate the ride height will be the same. To reduce ride height you need to reduce spring rate or preload. As you can't reduce preload you need to reduce the spring rate. This is why you need helper/tender springs to achieve a lower ride height rather than different length springs. Longer spring would allow a higher ride height as you can increase preload more before running out of adjustment on the shock body but I'm not sure this is what you're trying to achieve?If you have a longer spring you can pre load the spring at a bigger distance from the spring seat to the spring adjusting collar.I don't understand how longer springs would help. Surely if needs helper/tender springs?
I'll ask nitron if a 1 in longer spring would allow us to set the car to OEM ride height (140mm) without putting to much preload on the spring to avoid damaging the damper.My vx is 148mm all around when complete OEM. Fitted the nitrons and after adjustment this morning front is now 141mm with just 2 turns from lose spring. Maybe it will drop till 140mm tomorrow after bedding in over night but cant see this drop down to (148- 20mm) 128mm...
#237
Posted 23 January 2016 - 01:03 PM
I wouldnt panic about the fronts being loose too much. Main issue is keeping the rears in contacts. Fronts being loose doesn't worry too much.
With 17/17" wheel combo, 130/140mm ride height might be the lowest you want to go to keep the geometry at best. With 16" front wheel you loose some more height.
#238
Posted 23 January 2016 - 01:52 PM
#239
Posted 23 January 2016 - 02:14 PM
I run around 125/130 on my NSS(1). Rear springs are just about touching the collar but there is no preload at all. Fronts aren't flush with the collar but aren't below the base of the collar. When on 17s I was totally below the base of the collar when jacked up, which I was not comfortable with.
#240
Posted 23 January 2016 - 02:44 PM
As long as the rears are touching your ok. So 130f and 140r sounds right.
Also tagged with one or more of these keywords: nitron, street series, group buy
