#901
Posted 30 August 2016 - 09:41 PM
#903
Posted 10 September 2016 - 11:02 PM
Like it. He looked reasonably committed...This is how you do Zandvoort https://youtu.be/nvDDYYiNN2s
#904
Posted 11 September 2016 - 01:00 PM
Nice. Some interestingly tight lines. Sent from my iPhone using TapatalkThis is how you do Zandvoort https://youtu.be/nvDDYYiNN2s
#905
Posted 11 September 2016 - 01:17 PM
#906
Posted 11 September 2016 - 01:18 PM
Yeah, it does look like the lines in the picture someone posted a while back.Nice. Some interestingly tight lines. Sent from my iPhone using TapatalkThis is how you do Zandvoort https://youtu.be/nvDDYYiNN2s
#907
Posted 12 September 2016 - 08:23 AM
He knew exactly at 0.20 when that car in front was going to break.
Interesting take on the Hugenholtz.
May give that a try.
Looks like coasting, but i had a trainer once also pushing me to stay as close to the curb there as possible.
Edited by smiley, 12 September 2016 - 08:23 AM.
#908
Posted 12 September 2016 - 08:42 AM
#909
Posted 12 September 2016 - 08:55 AM
How about a small inventory on how the noise restiction crippeled people, and how much of the fun it took away?
Running spa will be no problem for all noisy boys, but there will be no hotel with a beach next to it.
Choices choices.
#910
Posted 12 September 2016 - 09:18 AM
And no real fun in an NA, id be full throttle for most of the lap.
#911
Posted 12 September 2016 - 09:32 AM
With your 2.07 at Zandvoort you are in SC teritory.
Not so sure how much you would loose out on SPA, but yes it's a high speed track with Kemmel and Blanchimont a clear overtaking point.
#912
Posted 12 September 2016 - 09:50 AM
It didn't really take fun away, as such, but I was very aware that I would be above the limit. In my morning sessions I behaved and then played more and more with valve as day went on. All was fine until my last session when I left valve open and was WOT past the meter... 98dB on driveby. I will happily return tho, the weekend was as much about mates with cars as it was track time. I might look into a dB insert, I think there is scope if I can get a local welding place on side.How about a small inventory on how the noise restiction crippeled people, and how much of the fun it took away?
#913
Posted 12 September 2016 - 10:06 AM
I had sound troubles there, but if you have them there, you can have them at almost all tracks now so it just needs to be resolved which it is.
I think spa wouldn't be half as much fun as Zandvoort, especially for some of the lower powered cars and lacks all the other things that make that trip always a good one.
Martin S
#914
Posted 12 September 2016 - 10:07 AM
hopefully there will be a road trip , it would be nice to meet up at a circuit with a trackday group and make that our start point for the tour. obviously that ties the tour dates down a bit , ideally you would want to go when it is not so daft hot in august, although high up the mountains it is a nice contrast to the hot valleys.
spa would work out better from a logistics, heading in the right direction
spoken to Jez at BoT and he wants to join us and was thinking about bring along a support vehicle
I will probably book up both Spa and Zandy as soon as dates go up
#915
Posted 12 September 2016 - 10:10 AM
Dijon? Noise limit: 100db drive by at track side *
Spa - Noise limit: 103db drive by - 15meters from edge of track & 107db static
#916
Posted 12 September 2016 - 10:23 AM
guessing from the frolic dates, but probably Zandy Fri 18th august
#917
Posted 12 September 2016 - 10:36 AM
Wrong.guessing from the frolic dates, but probably Zandy Fri 18th august
#918
Posted 12 September 2016 - 10:46 AM
#919
Posted 12 September 2016 - 11:09 AM
insider info
#920
Posted 22 September 2016 - 09:27 PM
Also tagged with one or more of these keywords: eurotrip
eurotrip
General Discussion →
Track Day Forum →
The French Frolic 2018. 4Th-10Th AugustStarted by pete-r , 16 Aug 2017 ![]() |
eurotrip
Track Day Forum →
Lot French Frolic 2017 - 21St = 26Th AugustStarted by siztenboots , 01 Sep 2016 ![]() |
eurotrip
Track Day Forum →
Lotus-On-Track Dijon , 22Nd August 2017Started by siztenboots , 25 Aug 2016 ![]() |
eurotrip
Track Day Forum →
French Frolic 2016Started by PaulCP , 02 Sep 2015 ![]() |
Bing (3)
