In America, everybody is spraying before throttle or before laminovas. I haven't found a installation that sprays after the laminovas
I think that's just because it's easier.
NickB777 is spraying (or has the capability to) after the Laminovas as he had his inlet manifold drilled and tpped for the nozzles.
Before TB you have a very good water/air mixing and never have an underpressure situation, so you don't have the risk of sucking water into the engine (at idle/low load; high underpressure) when your system/nozzle leaks...
Rob tested that system several times at Zandvoort and also had it armed on his dyno session, but he still saw IAT temps >80°C with his Harrop 80mm.
No where near the results as found here by Nick(?) who sprayed after the laminova cores...
Think we must do it the same as BMW made it there; spray after the chargecooler. This way you keep the highest T-difference over the chargecooler, making that work most efficient. If you pre-cool the air with water before the chargecooler, that can do almost no extra cooling anymore as the T-difference will now be much smaller.
But for high flowing Harrop builds reaching 400HP, we probably also need to look into the max flow capacity of the 4 stock Laminova cores.
Edited by Exmantaa, 09 November 2015 - 01:30 PM.
