Pro Alloy Group Buy
89 replies to this topic
#41 The Batman
Posted 15 November 2015 - 02:00 PM
This group buy will last another 4 days Vegybs - air intake pipe Co220 - 48L tank D-dawg83 - 48L tank Harboged - 48L tank Mayor Tom - 60L tank s1 Sterb - 48L tank s1 Dropping like flies now!
#42 gertje
gertje
  • 459 posts
Posted 15 November 2015 - 02:02 PM
Sorry
#43 The Batman
Posted 15 November 2015 - 02:07 PM
No worries at all dude chinky chinky
#44 cain-it
cain-it
  • 2 posts
Posted 15 November 2015 - 04:38 PM
Hi guys
I'm new to the forum, but an old hand from SELOC / Exiges... just heard about the GB
I'm interested in a long range tank for an Exige S240 MY 2010
Are there +VE / -VE's to the different sizes apart from cost?
Would need it in Dubai UAE, OK?
#45 The Batman
Posted 15 November 2015 - 04:47 PM
Hello, One is bigger one is smaller depends how much fuel you want to carry around with you :) Dubai is ok but postage will be extra :)
#46 cain-it
cain-it
  • 2 posts
Posted 15 November 2015 - 05:09 PM
Are both equal in terms of fitment ease? Fuel gauge accuracy? Fuel surge suppression?
Any idea about Dubai freight cost?
Ta
#47 The Batman
Posted 15 November 2015 - 05:19 PM
Pm me your address please The 60L is a little harder because it's much bigger. Have to make sure all the wiring etc is tucked well out the way. Both have anti surge foam and one way valves in and run original fuel gauge
#48 Jocke_D
Jocke_D
  • 407 posts
Posted 16 November 2015 - 09:26 AM
Looked at the website but found no header tank for the VX. I'm thinking about the tank normally used for SC charge cooling that I know (think) I've seen before. Does it not exist or has it been removed?
#49 The Batman
Posted 16 November 2015 - 09:28 AM
pro alloy do a tank a rectangular one that goes in boot or behind seats or do you mean the racing fab one that bolts onto the header tank bracket:?
i can supply both. the alloy racing fab one is cheaper and i do have one on the shelf
cheers
#50 The Batman
Posted 16 November 2015 - 04:27 PM
updated list:
D-dawg83 - 48L tank Sterb - 48L tank s1
Mayor Tom - 60L tank s1 (amsterdam)
haggi - 48L tank
2 europe people are out.. then there was 5!! mayortom and sterb you have pm
chinky chinky
#51 Jocke_D
Jocke_D
  • 407 posts
Posted 17 November 2015 - 07:41 AM
cheers
Didn't know there were two different ones but I think I mean "racing fab one". As shown in Smileys thread
Was looking for a plastic, more oem look, tank for my build but if I can get a proven solution at a decent price I just might get it.
How much would that set me back, incl shipping to Sweden?
#52 The Batman
Posted 17 November 2015 - 11:05 AM
Pm
#53 Mayor Tom
Mayor Tom
  • 6 posts
Posted 17 November 2015 - 08:16 PM
Still in doubt: 60 or 48 liter tank. Am a bit put off the 60 liter due to the mentioning of difficult of installation in the S1. Any more thoughts on the decision? Additional weight is not an issue: just don't fill it up to the brim in case of a track day :) . Extended range of 60 liter is favorable on weekend trips to Germany.
How long is the installation time of such a tank? I assume its a matter of:
- depressurizing fuel lines by pulling fuel pump fuse and starting until fuel starvation,
- removing LH seat, removing pump cover, disconnecting fuel pump wires and fuel pipes,
- lifting car, taking off under trays, hand brake cables,
- removing LH wheel + arch liner, disconnecting fuel hoses from filler neck,
- removing tank bay plate, drop tank
- tape up any cables/ wires inside fuel tank bay,
and then reinstall in reverse order.
Roughly 2 ~ 3 hours assuming to bolts are not spinning etc?
Edited by Mayor Tom, 17 November 2015 - 08:16 PM.
#54 The Batman
Posted 17 November 2015 - 08:22 PM
It's probably only extra half hour on top of a 48L installation
#55 Mayor Tom
Mayor Tom
  • 6 posts
Posted 17 November 2015 - 08:30 PM
I want to replace the 1997 fuel hoses from the filler neck to the tank at the same time. Are the standard type remained, regardless of the 48 or 60 liter?
Anyone can share experience with the 60 l version?
And I assume the fuel level reading is off when the bigger tank is installed and the Stack just indicates full for a long time? So its better to focus on the trip milage to have an indication?
Edited by Mayor Tom, 17 November 2015 - 08:33 PM.
#56 The Batman
Posted 17 November 2015 - 08:48 PM
The fuel level is the same but it will say full until it goes into range. Do you want to have internal pump still? If you want external pump then you can have AN fittings on the side of the tank and just use the fuel pump canister for fuel level you will the. Need to run all new lines
#57 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 17 November 2015 - 11:56 PM
I want to replace the 1997 fuel hoses from the filler neck to the tank at the same time. Are the standard type remained, regardless of the 48 or 60 liter?   Anyone can share experience with the 60 l version?   And I assume the fuel level reading is off when the bigger tank is installed and the Stack just indicates full for a long time? So its better to focus on the trip milage to have an indication?
Not unless you change the stack so it reads properly.
#58 Mayor Tom
Mayor Tom
  • 6 posts
Posted 18 November 2015 - 06:35 AM
How is this done, changing the stack? And I assume something has to change to the fuel level sensor too? So it can reach the entire fuel level range?
I intent to retain the OEM fuel pump set-up inside the tank.
#59 The Batman
Posted 18 November 2015 - 10:26 AM
Haggi has a aftermarket dash. Not worth the effort in my mind
Edited by The Batman, 18 November 2015 - 10:26 AM.
#60 techieboy
Posted 18 November 2015 - 10:33 AM
and pointless too, unless you get a new sender that you can fit to the deepest part of the tank and calibrate the output to suit. If your in-tank pump and sender fit in the original shallower position, it'll just read full until the extra capacity is used up whatever you fit.
