I used these from ebay.....
http://www.ebay.co.uk/itm/371143158736
1) Remove Headlight (One securing bolt)
2)Unplug both fog and main light harness
3)Find suitable location for DRL Control unit
4)Tape up Fog Harness
5)Attach positive and negative of DRL unit to battery
6) Locate side light power cable on light harness (Red cable)
Connect white cable from DRL unit to red power cable (This dims the DRL's by 30% when lights are switched on)
7)Remove old fog unit (This can be a real pain in the ass if youve never done it before, may have to grind out old screws from mount, so be prepared)
Alittle tip would be to use the fog light hole to unscrew the fog from its mount, its fiddly but defo works.....much better than removing the front clam!
8) Remove mount screw from fog bracket
9) I used some plastic shelving as a rear mount
10) I made a circle - diameter of 115mm
11) Mark where you are going to drill holes and drillllllll, I used M4 bolts and nuts, so used a 5mm drill bit
12) Drill a hole for the DRL Power harness to go through
13) Screw and bolt in place onto fog mount
Edited by techieboy, 15 November 2015 - 12:56 AM.
