Evora Buyers Guide
#21
Posted 29 November 2015 - 08:59 PM
#22
Posted 29 November 2015 - 09:25 PM
Go for it 👍The NA evora doesn't hang about - it seems quicker than I expected based on the specs. I followed for a bit at Snetterton and you wasn't hanging around then either. I'll dig put the footage if interested.
Two Evora's come past just as I exit the pits on my outlap (I assume you're in the Yellow one?). You see more of the Evora from 2:10. It's certainly not lacking pace down the straight (2:25). It must be a very healthy 275 horses and corners very flat considering the reported road comfort!
I loaded the whole session as it also included JG (after I get past the peugeot) who's exhaust is also clearly audible over the vx SC whine...
Edited by Captain Vimes, 29 November 2015 - 09:25 PM.
#23
Posted 29 November 2015 - 09:30 PM
#24
Posted 29 November 2015 - 09:33 PM
#25
Posted 29 November 2015 - 10:15 PM
Didn't see that coming!Cough.
#26
Posted 29 November 2015 - 11:06 PM
Power to weight is definitely down in the Evora at 276bhp/1380kg but it just seems to want to pull and pull, plus it really inspires the driver to push harder.
This, along with the bizarre rear end styling are my issues with the Evora. Was the target weight really 1.4 tons for a compact 2+2 made of aluminium and fibreglass?!
#27
Posted 29 November 2015 - 11:24 PM
Edited by rickyzero, 29 November 2015 - 11:27 PM.
#28
Posted 29 November 2015 - 11:27 PM
The VX isn't exactly a looker from the back !
#29
Posted 30 November 2015 - 09:18 AM
#30
Posted 30 November 2015 - 09:35 AM
James, your old rusty vauxhall now gone then ?
New Lotus sat on drive
#31
Posted 30 November 2015 - 09:36 AM
#32
Posted 30 November 2015 - 09:50 AM
10/10 for spotting it though Sherlock
#33
Posted 30 November 2015 - 11:59 AM
#34
Posted 30 November 2015 - 12:49 PM
I'm not sure if there are "problems" as such. I guess someone like Jez could comment on how many he's changed? I know of several at 40-50k on their original clutches. It is however, a clam off job, so could be as high as £2-£3k depending on labour rates and how much of the clam removal you do in advance. In that respect, it's like a big VX to take the rear clam off. I think if I needed a clutch, I'd remove the rear clam and then have it recovered to BoT to have them do the actual clutch work.No mention of the clutch problems?
#35
Posted 30 November 2015 - 12:59 PM
Jez hasnt changed any but he's had quite a few with the problem. By coincidence the ones hes seen have been under a warranty as the owners have recently bought them. One of the recent ones was an Evora bought from Targa Florio Cars that the owner asked Jez to look at at the Lotus Festival. The owner noticed a rattle when he bought it but was told TADT. The rattle got worse and then the clutch pedal action changed, getting stiffer I believe but also changing height. I'm not sure of exactly what happens but its something to do with a bush that wears causing a rattle and ultimately clutch failure. Clutch change is engine out and the cheapest I've heard is £3k. They seem to fail around 30k miles
#36
Posted 30 November 2015 - 01:13 PM
Edited by PaulCP, 30 November 2015 - 01:20 PM.
#37
Posted 30 November 2015 - 01:26 PM
"Not really high" does not quantify it. That guide on SELOC says its the bearing. Whether the bearing or a bush (I've always heard that its a bush) there is a problem with premature clutch wear on the Evora and the V6 Exige. The master cylinder failure is not of real concern as its reasonably cheap to replace and is evident if the pedal bite height is changing. If there is a noise like the SELOC guide describes then that is a precursor of clutch failure. It says some owners got Lotus to "address it undere warranty" so Lotus are aware of it
#38
Posted 30 November 2015 - 01:32 PM
I think Lee was just trying to provide an brief insight following a few questions rather than an authoritive guide😉
I'm sure and, of course, I'm not criticising his efforts. I'm just pointing out that if people are reading this and considering an Evora they should be aware of this. I agree, its only a small amount of the cars built that are affected and its not something that would stop me buying one, I still intend to at some point however a buyer has to be extra careful and really listen for this transmission noise as the SELOC guide describes it.
#39
Posted 30 November 2015 - 01:58 PM
#40
Posted 30 November 2015 - 02:14 PM
People should be aware that the release bearing rattling seems to be a different fault from the bush wear that causes clurtch failure
