Decided to deal with my weepy sandwich plate seals as they have suddenly started to leak badly. Inevitably the cap unscrewed the sandwich plate adapter ring and I've spent the whole effing day trying to separate the two. Can't find the magic solution on the forum and I know lots have had the same problem, help please! Thanks in anticipation chaps.
Na Oil Filter Cap Stuck To Adapter Ring
Posted 03 December 2015 - 09:19 PM
Posted 03 December 2015 - 09:24 PM
I used a turner and a big file as a crowbar.
Put the lid part in the turner and the file in the holes in the ring and added force on the file.
Posted 04 December 2015 - 07:32 AM
Posted 04 December 2015 - 08:37 AM
Posted 04 December 2015 - 08:48 AM
I put the hex in the vice and use a massive pair of plumbers pliers to free the over-tightened lid.
But ..... you must replace the O ring seal, which is most likely old and worn out, plus the reason for over-tightening it in the first place.
Posted 05 December 2015 - 02:36 PM
Cheers Chaps, scholars and gentlemen all, your help and advice much appreciated! I have one of your special spanners Chippy, very carefully fettled to a really snug fit and I have spare 'O' rings Vocky, and finally got it all split apart this afternoon by clamping the hex in the vice and welting the spanner, exactly as you suggested FLD. I would have put it in the lathe but it's a wood lathe so not a lot of use for this without a lot of fiddling! Thanks again!!
Also tagged with one or more of these keywords: oil, filter, cap, adapter, ring
General Discussion →
VX220 Discussion →
Remove Canister And ProblemsStarted by simoambro97 , 16 Aug 2020 ![]() |
VX220 Discussion →
Oil Filter ChangeStarted by martinf , 11 Nov 2019 ![]() |
The Market Place →
Car Parts Wanted →
Little Silver Cap For Starter ButtonStarted by MattMacc123 , 19 Apr 2018 ![]() |
VX220 Discussion →
Oil Dipstick Level With Saab Sump?Started by ee601 , 02 Apr 2017 ![]() |
VX220 Discussion →
Oil Sandwich Plate Filter GasketsStarted by KrazyHazy , 01 Jun 2016 ![]() |
