Have I Got Fuel Pump Problems?
24 replies to this topic
#1 Ebo100
Ebo100
  • 654 posts
Posted 08 December 2015 - 08:49 PM
My VXT failed to start this morning. We have had some torrential rain in the last couple of days so I just put it down to a damp coil pack. I put the battery on charge and left for work.
Tonight I've taken the coilpack off and refitting the plugs have found I have good sparks across all plugs. The battery is spinning the engine over fine. A look in the boot shows all is dry in there and I have tried swapping the grey relays around. The contacts all look in good condition and when the key is turned I can feel them working.
At the fuel rail; pressing the valve only gives the briefest of squirts with only a small amount of fuel flowing. Turning the engine over creates a small amount of pressure and gives a small squirt again. I can normally hear the pump priming but today there is nothing, and leaving the ignition on while working the fuel rail valve does not give the continuous squirt that is mentioned on other threads.
Is this all pointing to the fuel pump or could it still be a relay problem?
Is there anything else I can check? Any help gratefully received.
#2 FLD
Posted 08 December 2015 - 08:52 PM
Have you checked the cut-off switch?  Red button at the rear of the subframe on the pass side of the engine bay.
#3 Ebo100
Ebo100
  • 654 posts
Posted 08 December 2015 - 08:59 PM
Yeah forgot to mention that. I've pressed the rubber down. If it had triggered would I be able to feel it sticking up?
I did hit a phesant last night but it did keep driving for another half a mile before my house and ticked over on the drive for a while.
#4 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 December 2015 - 09:12 PM
Sounds like a similar issue to mine. Not solved it yet so I'll be watching this with interest!
#5 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 08 December 2015 - 11:06 PM
Could try shorting across the relay socket to manually feed the fuel pump.
#6 smiley
Posted 08 December 2015 - 11:13 PM
Any codes in the ecu?
#7 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 09 December 2015 - 08:38 AM
The fuel rail will only prime once till the engine is running
Disconnect the MAF to see if the car fires
Make sure you reseat the yellow starter relay
These cars are becoming old timers now
#8 FLD
Posted 09 December 2015 - 09:05 AM
Check the contacts for corrosion. There's the ones on the pump itself and then there's the one in the loom of doom plugs (big pink and brown wire iirc). I had a weak pump which turned out to be wiring. It just couldn't get the current to run fully. Swapped the corroded terminals and all was well again. Quieter too!
#9 Ebo100
Ebo100
  • 654 posts
Posted 09 December 2015 - 12:32 PM
Do I just need to loop a length of wire over two of the sockets?
No codes (for a change :))
Cheers, I'll try this later, would the MAF stop the fuel flow?
thumbsup thanks I'll check this over tonight.
#10 FLD
Posted 09 December 2015 - 02:11 PM
Good luck dude. It's not nice when they won't run.
#11 quimbles
quimbles
  • 760 posts
Posted 09 December 2015 - 02:16 PM
Another for the loom of doom.
i had very similar problems a couple of months back... fuel pump wasnt priming, car wouldnt start.
pump was dead, current checked out ok... fitted new pump and that blew in 10miles.
double and triple checked current and found it to be intermittent.... traced wires as best i could back to the loom and found some corrosion and replaced the dodgy bits.
now all ok!
#12 FLD
Posted 09 December 2015 - 05:22 PM
I have a spare pump if you find you have this problem.
#13 Spitfire Engineering
  • 755 posts
Posted 09 December 2015 - 07:43 PM
now all ok!
You burned out a new pump in 10 miles???
Gaz
#14 quimbles
quimbles
  • 760 posts
Posted 10 December 2015 - 10:45 AM
yep!  burnt it out.  id say it was due to my driving but more like my bad mechanics on the first pump replacement. :)
#15 Nev
Posted 10 December 2015 - 11:18 AM
Pumps can burn out fast if they don't have any fuel to pump sometimes, as they need the petrol as a lubricant and also as a resistance to work against.
Edited by Nev, 10 December 2015 - 11:19 AM.
#16 Spitfire Engineering
  • 755 posts
Posted 10 December 2015 - 12:06 PM
Any details?
unit model?
pump?
etc?
were you not offered some sort or warrenty?
very unusual
Gaz
#17 quimbles
quimbles
  • 760 posts
Posted 10 December 2015 - 04:14 PM
1st pump to fail was the original pump. checked voltage, relays etc all appeared ok.
2nd pump was a wahlbro from courtenays.... sent it back for inspection but got nada. cant grumble too much as it wasnt the pump at fault.
3rd pump is same as above. since the loom damage has been repaired car has done i guess 1k miles and a couple of trackdays and all is ok.
#18 Spitfire Engineering
  • 755 posts
Posted 10 December 2015 - 07:16 PM
Not so unusual after all then   :)
Thanks for theinfo
Gaz
#19 wellsey
wellsey
  • 56 posts
Posted 10 December 2015 - 08:55 PM
Had the same thing happen last month fuel pump not priming check all wiring and fuses in the inner rear arch liner in the boot!! Mine had melted had an auto electrician round £40 later sorted
#20 Spitfire Engineering
  • 755 posts
Posted 10 December 2015 - 10:00 PM
Std pump though?
