Suspension Refresh
79 replies to this topic
#21 Alastair
Alastair
  • 637 posts
Posted 15 December 2015 - 04:41 PM
Seriously Lotus have replied, and will shortly have a generic Christmas discount of between 5% and 10% for some items (inc suspension refresh kit), so no group buy required.
#22 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 December 2015 - 06:10 PM
That's a worthwhile discount.
#23 Tommo
Tommo
  • 344 posts
Posted 16 December 2015 - 12:44 PM
i think i'll keep my eye out for that then!
#24 Raptor
Raptor
  • 942 posts
Posted 16 December 2015 - 01:03 PM
Yep I'll be up for the SL kit.
#25 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 16 December 2015 - 07:20 PM
I only started as a replace the charge cooler which ended up with suspension refresh, nitrons and a lot of "while I'm there"
#26 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 16 December 2015 - 08:08 PM
Lol. This seems to happen a lot.
#27 Tommo
Tommo
  • 344 posts
Posted 18 December 2015 - 08:49 AM
The SL suspension refresh kit is in their sale section now.
Only £14 knocked off but its better than a kick in the Jacobs.
#28 Alastair
Alastair
  • 637 posts
Posted 18 December 2015 - 09:43 AM
He did mention to me there would be 5% of the refresh kit, and an additional 5% discount on top, a generic all site discount code. Only the first 5% seems to have been delivered. I will drop him an email and seek clarification.
#29 Tommo
Tommo
  • 344 posts
Posted 18 December 2015 - 12:12 PM
thumbsup
Ah, OK. I'll hang fire then!
cheers.
#30 Alastair
Alastair
  • 637 posts
Posted 18 December 2015 - 12:22 PM
I should havere ad his email better... the discount will be applied in a few days..... "I am about to upload a 5% across the board discount for the period 23/12/15 to 31/12/15 There will also be further discounts on some items, including an extra 5% on suspension kits, so 10% in total, any good?? I also have the Spitfire toe links for the VX in stock as well as uprated fuel pumps (complete) again from Spitfire The Discount period will be activated using the code XMAS2015 and will show in the total as additional doiscount in customers baskets"
#31 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 December 2015 - 05:13 PM
I am thinking of replacing all 16 wishbone bushes, 8 wishbone ball joints, track rod ends and anti-roll bar drop links when the weather is warmer.
I have heard the wishbone bush bolts can weld themselves to the bush making it very difficult to remove the wishbone. Does anyone know a way round this? Maybe a special tool to get the stuck bolt out the bush?
#32 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 December 2015 - 05:14 PM
Fast forward to 4 minutes for the issue.
#33 Alastair
Alastair
  • 637 posts
Posted 27 December 2015 - 02:21 PM
Anyone have any opinion on the choice of bushes? Poly vs. rubber? (Seriously Lotus wishbone bushes or Superpro). I assume rubber is more compliant for road, super pro a little stiffer and track biased?
#34 hairy
hairy
    Moonlander
  • 6,020 posts
Posted 27 December 2015 - 04:13 PM
From SELOC WIKI (http://wiki.seloc.or...wishbone_bushes):
  • OEM - Good ride quality, ideal for normal road, fast road and track use. The central steel sleeve is bonded to the rubber so it does not pivot around it freely.
  • Polyurethene - Good ride quality, ideal for normal road, fast road and track use. The central sleeve rotates freely within the bush.
  • Nylatron - Firm ride quality and not recommended for normal road use, ideal for fast road and track use. The central sleeve rotates freely within the bush.
  • Spherical Joints - Harsh ride quality and recommended for track use only. These are not bushes, but close tolerance stainless steel bearings, commonly known as Rose Joints and need to be welded into the wishbones. These are not suitable as DIY replacements.
OEM wishbone bushes do not require periodic maintenance. Maintaining polyurethene and nylatron bushes is much easier than fitting them. The wishbones do not need to be completely removed from the car if you need to re-grease the sleeves. All wishbones can be removed from the chassis by just taking out the wishbone bolts and sliding the wishbones out. All other suspension and brake components can remain in place. Only the brake pipe clamps need to be removed and care must be taken to ensure that the brake pipes are not under strain when maintaining the bushes.
#35 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 29 December 2015 - 05:09 AM
Does anyone happen to know off hand what the bolt sizes are (chassis side, upper and lower, front and rear). I'm not at home for the next 2 weeks to measure myself (foresight!), and will be right next door to a major fastener wholesaler where I can get all manner of sexy bolts for not much. If someone could tell me the bolt lengths (under head length), dia, and amount of unthreaded shaft required at each position, I can make a list and go buy a bag full of bolts :) Front upper - fore: - aft: Front lower - fore: - aft: Rear upper - fore: - aft: Rear lower - fore: - aft: Cheers Ed
Edited by ed.oates, 29 December 2015 - 05:11 AM.
#36 Arno
Arno
  • 1,238 posts
Posted 29 December 2015 - 07:38 AM
Knock yourself out...
http://speedsterclub...ones/index.html
And all the other pages ;)
#37 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 29 December 2015 - 07:55 AM
Yet another forum I need to register to... Lol Thanks for the tip
#38 Exmantaa
Posted 29 December 2015 - 09:22 AM
I would not bother and simply buy a complete suspension replacement set from f.i. Elise shop (€35 for every bolt, nut and washer you might need)
And while your're there; buy the higher tensile strength replacement upright bolts too...
#39 smiley
Posted 29 December 2015 - 09:46 AM
No, the dutch forum is fully open to anonymous.
Edited by smiley, 29 December 2015 - 09:46 AM.
#40 slindborg
Posted 29 December 2015 - 10:00 AM
I would not bother and simply buy a complete suspension replacement set from f.i. Elise shop (35 for every bolt, nut and washer you might need) And while your're there; buy the higher tensile strength replacement upright bolts too...
Your logic and sense won't work with that one..... Hence why he's on my list :lol:
