Suspension Refresh
#61
Posted 07 January 2016 - 09:19 AM
#62
Posted 07 January 2016 - 10:02 AM
#63
Posted 07 January 2016 - 11:20 AM
You worry too much😄😄I'm not sure if you can go overkill with these things if the car has a lot of life left. What worries me is whether or not it's worth protecting a wishbone that is already thin from years of rust?
#64
Posted 07 January 2016 - 04:04 PM
When people say that you know there is something to actually worry aboutYou worry too muchI'm not sure if you can go overkill with these things if the car has a lot of life left. What worries me is whether or not it's worth protecting a wishbone that is already thin from years of rust?
#65
Posted 07 January 2016 - 04:46 PM
Well, in that case, you definitely worry far, far too much 😄😄😄When people say that you know there is something to actually worry aboutYou worry too much��I'm not sure if you can go overkill with these things if the car has a lot of life left. What worries me is whether or not it's worth protecting a wishbone that is already thin from years of rust?
#66
Posted 07 January 2016 - 06:43 PM
#67
Posted 07 January 2016 - 07:31 PM
#68
Posted 07 January 2016 - 07:48 PM
Edited by gaffer1986, 07 January 2016 - 07:49 PM.
#69
Posted 07 January 2016 - 08:22 PM
#70
Posted 08 January 2016 - 02:18 AM
#71
Posted 08 January 2016 - 01:20 PM
My tips
1. Buy this:
https://www.machinem...oint-separator/
It will save you a heap of time splitting the ball joints
2. Get some proper marine grade grease if you go for any of the fancier bushes. I did and never had a problem. Ertacetal bushes felt wonderful on my car. Ask anyone who's driven it. Quite bored of seeing people not recommend them for road use even though they've never tried them....
3. Don't grease the threads on bolts.
4. It will take time. No matter your ambition it will take longer than you think and you will not enjoy it. Accept it or get someone else to do it.
5. It's worth it.
Edited by LY_Scott, 08 January 2016 - 01:20 PM.
#72
Posted 08 January 2016 - 06:11 PM
#73
Posted 08 January 2016 - 09:07 PM
How do you measure the depth?Rust is seven times the volume of steel. Despite the theories other metal oxides aren't all that protective either! The trick with corrosion is to measure the depth of loss.
#74
Posted 09 January 2016 - 11:01 AM
Sonething like this for the grease?My tips
1. Buy this:
5. It's worth it.
Edited by D-DAWG83, 09 January 2016 - 11:02 AM.
#75
#76
Posted 09 January 2016 - 11:02 AM
#77
Posted 09 January 2016 - 01:10 PM
There's a special tool for measuring depth of pits.How do you measure the depth?Rust is seven times the volume of steel. Despite the theories other metal oxides aren't all that protective either! The trick with corrosion is to measure the depth of loss.
#78
Posted 09 January 2016 - 01:11 PM
#79
Posted 09 January 2016 - 05:19 PM
#80
Posted 09 January 2016 - 07:08 PM
