Edited by ed.oates, 17 December 2015 - 10:50 PM.
Tesla Roadster Big Brakes ?
Posted 17 December 2015 - 10:48 PM
Posted 18 December 2015 - 07:02 AM
Lots of us use 308 discs with 4 pot callipers which are a direct fit to the vx front upright.
you don't need new uprights, a spacer and a longer bolt is ok to use 308 discs with standard callipers and standard uprights.
I'm not convinced you'd notice the difference though.
Posted 18 December 2015 - 07:05 AM
The standard rotors from the Saab 9-5 Aero is a direct fit. You just need to space out the calipers. Feels like most bang for the buck if you just want bigger rotors.
Obviously there are more sporty options than the standard ones for the Saab as well if you want less weight or more bite.
Posted 18 December 2015 - 07:07 AM
As far as I know do the Tesla Roadsters run somewhat oddball disc sizes as standard something like 300mm front and 310mm rear, not 308.
It's close, but if you look around this is a common 'search' for Tesla Roadster owners to find suitable aftermarket discs that fit as these are such uncommon sizes.
Uprights my still be a decent starting point for bigger brakes on the VX, but may still need some fettling/mods to the claiper mounts for different sized discs.
Posted 18 December 2015 - 08:31 AM
Posted 18 December 2015 - 08:45 AM
It's a nice option for the rear. Are you sure it's the upright that's different and not the caliper?
Posted 18 December 2015 - 08:48 AM
Think how expensive the VX upright is. Then wonder at just how much an even more limited version for a shitty low volume bodge of an electric car could be.
Posted 18 December 2015 - 08:51 AM
http://www.teslamoto...ll=1#post408566
Looks like the same upright to me
Edited by fezzasus, 18 December 2015 - 08:52 AM.
Posted 18 December 2015 - 09:26 AM
Find it none the less interesting that there's no mention of the tesla stuff on the forums at all.
I once mentioned the testla's fondmetal 7400 rims, but it was not received well here. (photoshopped)
Edited by smiley, 18 December 2015 - 09:27 AM.
Posted 18 December 2015 - 11:42 AM
but theyre not
some bloke had the lotus uprights next to the tesla's... the rears calipers are identical to the lotus, and the mounting ears on the upright are therefor bigger to accommodate the bigger disc
fronts... are unclear. he originally said the uprights were different, but then corrected himself and said the caliper is different (standoff) to accomodate the reach around thr rotors
the guy who sent me the pics of the brakes yesterday is measuring things again - as i find the 308/308 size a little unlikely
Posted 18 December 2015 - 12:54 PM
Posted 18 December 2015 - 01:39 PM
Its truly amazing that nobody bothered/wondered/mentioned about this in years and just now that I dived into this myself last week, somebody comes up with exact the same thing...
And yes, the Tesla rear upright castings seem to have a bit more elongated caliper mounts to accomodate the 308mm discs.
Posted 18 December 2015 - 02:33 PM
Posted 18 December 2015 - 03:41 PM
I wonder if the rear uprights are available from lotus and if they're the tapered or straight toelink hole?
Posted 18 December 2015 - 03:48 PM
the A116 items are only £140 + vat each, hopefully the tesla versions are a similar price .....
Posted 18 December 2015 - 03:49 PM
What is on a Europa SE, as this also has the 308mm discs OEM? (I recall something about 4-pot calipers front & back? But what about the required parking brake then?)
Posted 18 December 2015 - 03:52 PM
A116 rears - same as vx220
SE had 308mm and 4 pots on front only, according to the parts list
Edited by vocky, 18 December 2015 - 03:53 PM.
Posted 18 December 2015 - 04:04 PM
Later ones have different uprights with a disc/drum hybrid. Its a completely different set up.
Edited by FLD, 18 December 2015 - 04:04 PM.
Posted 18 December 2015 - 04:12 PM
That's interesting... That's probably for the 4-pot rears, but that would imply some different shaped rear uprights to accomodate all this.
Posted 18 December 2015 - 04:13 PM
I've emailed Podge, waiting on a reply.
