Tesla Roadster Big Brakes ?
79 replies to this topic
#21 vocky
Posted 18 December 2015 - 04:29 PM
Later ones have different uprights with a disc/drum hybrid.  Its a completely different set up.
That's interesting... That's probably for the 4-pot rears, but that would imply some different shaped rear uprights to accomodate all this. :unsure:
thought that was only the Evora - http://www.deroure.c...&SMO=0&ST=&SC=0
Europa SE http://www.deroure.c...&SMO=0&ST=&SC=0
Edited by vocky, 18 December 2015 - 04:30 PM.
#22 FLD
Posted 18 December 2015 - 04:35 PM
I meant later models.  Its completely different suspension set up so non-transferable.
Sorry for the confusion.
#23 Exmantaa
Posted 18 December 2015 - 04:39 PM
The Exige S V6 is indeed completely different at the rear. (Subframe, A-arms, uprights, toelinks, brakes. All different.)
#24 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 18 December 2015 - 04:41 PM
do any of the evora calipers fit the front upright of the vx?
#25 Arno
Arno
  • 1,238 posts
Posted 18 December 2015 - 05:55 PM
Yup.. Because the back-end is lifted almost 1:1 from the Evora and has it's complete rear suspension.
Also the reason why the V6 Elise/Exige has 2 different bolt-patterns for wheels:
- 5x110 (aka. VX/Speedster/Europa) front
- 5x114.3 from the Evora (donated by a Toyota) rear
Makes wheel selection.. Umm.. 'Interesting'...
#26 vocky
Posted 18 December 2015 - 06:02 PM
those Tesla rear hub carriers must be for 298mm discs
vx220 standard rear disc is 288mm, therefore the caliper mounts would have to be 20mm further out for 308mm discs and going by the photo in the link (on page 1 of this thread) the threaded caliper mounting holes are no more than 10mm further away from the centre line.
Edited by vocky, 18 December 2015 - 06:02 PM.
#27 Exmantaa
Posted 18 December 2015 - 06:22 PM
Something to do with radius and diameter....  :sleep:
#28 Doctor Ed
Doctor Ed
  • 1,188 posts
err... Divide by 2
#29 vocky
Posted 18 December 2015 - 08:23 PM
I will ask Santa for a new brain  :blush:  :lol:
#30 siztenboots
Posted 19 December 2015 - 12:40 PM
only Lotus could do this , so mismatched hubs , discs , wheels
#31 FLD
Posted 24 December 2015 - 09:16 AM
Lotus won't supply Tesla parts so we'd have to go via a Tesla dealer $$$
#32 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 24 December 2015 - 11:58 PM
i bought myself a set... will update when stuff arrives
#33 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 25 December 2015 - 11:33 AM
Can these 5/114.3 wheel bearing hubs be fitted to the VX220 front and rear? Br,Per
  Yup.. Because the back-end is lifted almost 1:1 from the Evora and has it's complete rear suspension.   Also the reason why the V6 Elise/Exige has 2 different bolt-patterns for wheels:   - 5x110 (aka. VX/Speedster/Europa) front - 5x114.3 from the Evora (donated by a Toyota) rear   Makes wheel selection.. Umm.. 'Interesting'...   Bye, Arno.
#34 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 25 December 2015 - 07:53 PM
Nope
#35 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 25 December 2015 - 09:24 PM
Why?
#36 Arno
Arno
  • 1,238 posts
Posted 25 December 2015 - 09:45 PM
Rear of the V6 Elise shares the rear uprights off of the Evora and they are completely different parts from the Speedster.
Exige V6 rear suspension with 114.3x5:
Europa rear suspension (same as Speedster):
Most of the Evora and rear Elise-V6 parts come from the Toyota parts bin while the S2 Elise and Speedster is built up from mostly Opel/Vauxhall bits. They are not compatible without modifying parts.
Not saying it could not be done in some way with enough time and effort and money, just that it's not a direct fit.
#37 vocky
Posted 26 December 2015 - 10:05 AM
part numbers ?
supplier ?
rough cost ?
#38 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 26 December 2015 - 10:07 AM
What does Evora have inte front for bolt pattern?
#39 vocky
Posted 26 December 2015 - 10:11 AM
same pattern as the back - because it has the same hub on the front as the back
Edited by vocky, 26 December 2015 - 10:12 AM.
#40 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 26 December 2015 - 10:23 AM
  part numbers ?   supplier ?   rough cost ?
Second hand coincidental find. 100 per corner inc hubs and rotors, without calipers.
Edited by ed.oates, 26 December 2015 - 10:24 AM.
