Oil Breather Guide For Na
20 replies to this topic
#1 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 December 2015 - 09:43 PM
Buy these parts: 1/2" petrol hose, oil breather filter the fits the petrol hose and a jubilee clip. You will also need a cable tie.
Posted Image20151220_122803_001 by Richard Fanders, on Flickr
Then it starts raining!
Posted Image20151220_122825 by Richard Fanders, on Flickr
Locate oil breather:
Posted Imageoil-breather by Richard Fanders, on Flickr
Posted Imageoil-breather-closer by Richard Fanders, on Flickr
Remove using a similar tool (fairly easy to get off):
Posted Image20151220_115310 by Richard Fanders, on Flickr
Posted Image20151220_115157 by Richard Fanders, on Flickr
Posted Image20151220_115200 by Richard Fanders, on Flickr
Posted Imageoil-breather-hole by Richard Fanders, on Flickr
Clean using these - I think this is important to help prevent it coming off:
Posted Image20151220_123929 by Richard Fanders, on Flickr
Posted Image20151220_124152 by Richard Fanders, on Flickr
#2 gaffer1986
gaffer1986
  • 4,408 posts
Put hose in engine bay to measure up and cut:
Posted Image20151220_123255 by Richard Fanders, on Flickr
Cut hose to relevant size and add the jubilee clip and filter:
Posted Image20151220_124554 by Richard Fanders, on Flickr
Posted Image20151220_125736 by Richard Fanders, on Flickr
Push the hose over the breather hole and tighten jubilee clip - if it's a tight fit (1/2" pipe won't be) you can heat the pipe in boiling water to soften it:
Posted Image20151220_130227 by Richard Fanders, on Flickr
I held the jubilee clip close to the metal plate thingy that the gear selector connects to with my lever tool. It feels very secure and I would struggle to pull it off:
Posted Image20151220_131102 by Richard Fanders, on Flickr
Cable tie breather to the header tank under the clam to prevent water getting into it:
Posted Image20151220_132308 by Richard Fanders, on Flickr
I added velcro to stop any possible rattling:
Posted Image20151220_132605 by Richard Fanders, on Flickr
Then clean my car after 1000 miles and two track days:
Posted Image20151220_132633 by Richard Fanders, on Flickr
Posted Image20151220_151536 by Richard Fanders, on Flickr
And off to Sainsbury's to buy my mum a birthday present:
Posted Image20151220_155202 by Richard Fanders, on Flickr
#3 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 December 2015 - 09:44 PM
Total cost about £15
#4 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 December 2015 - 09:47 PM
Complete job:
Posted Image20151220_132326 by Richard Fanders, on Flickr
#5 jim61
jim61
  • 384 posts
Posted 22 December 2015 - 09:56 PM
Nice one ! Another good "how to" 👍
#6 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 December 2015 - 10:19 PM
I forgot the mention that this modification is essential for track days to prevent oil coming out the breather hole. It went on my wheel at snetterton.
#7 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 22 December 2015 - 11:27 PM
Mod should move this to guides area. Always good to keep updated ones Good post
#8 Baron Von Scubadaddy
  • 6,644 posts
Posted 22 December 2015 - 11:53 PM
Nice work !
#9 FLD
Posted 23 December 2015 - 08:46 AM
Top job, I hope that was your better halfs tooth brush ;)
#10 Mattyboi
Mattyboi
  • 482 posts
Posted 23 December 2015 - 09:48 AM
Very true!
This happened to me and I instantly thought "its dead. sh*t.". Luckily there were org`ers on hand to tell me where it was from.
#11 marty64
marty64
  • 38 posts
Posted 27 December 2015 - 07:54 PM
Thank You Gaffer !  B)
Nice "How to", but what's the advantage to do this ?
Size are same for a SC engine ?
#12 gaffer1986
gaffer1986
  • 4,408 posts
Posted 28 December 2015 - 12:23 PM
Thank You Gaffer !  B)   Nice "How to", but what's the advantage to do this ?  Size are same for a SC engine ?
Thank you. If you track your car oil spits out the breather hole. I'm not sure about SC cars, depends if you're using the original gearbox. I think the original gearbox is called an F23?
Edited by gaffer1986, 28 December 2015 - 12:24 PM.
#13 Ormes
Ormes
  • 4,612 posts
Posted 28 December 2015 - 12:33 PM
Yep, F23 for NA and Turbo albeit different variants... your mod works with either as the selector mechanism and breather outlet are in the same location.  Only other variant is an M32 transplant but few have done this.
#14 gaffer1986
gaffer1986
  • 4,408 posts
Posted 28 December 2015 - 01:07 PM
Also I hear some people put the Zafira equivalent of the F23 gearbox in these cars to increase revs. I'm not sure of the advantage of an M32 transplant although I hear they're unreliable gearboxes.
#15 Ormes
Ormes
  • 4,612 posts
Posted 28 December 2015 - 01:28 PM
Yep, different final drive on Zaf F23 for a closer ratio.  M32 is 6 speed and another way of achieving a close ratio but with the added advantage of keeping the revs down when cruising on the motorway.  Like you, I heard they are even more chocolaty than the F23.
#16 gaffer1986
gaffer1986
  • 4,408 posts
Posted 30 December 2015 - 11:18 PM
Haha, chocolaty! Better than stirring porridge.
#17 Ragged Roy
Ragged Roy
  • 19 posts
  • Interests:VX220, classic Mini, Yamaha R1, Wakeboarding, Kitesurfing, Hairy Pussy/ Maine Coon (cat).
Posted 23 May 2020 - 04:59 AM
Would this work? I’m thinking of blanking off the existing gearbox breather and adding the adapter I have made to the fill hole. The new solid pipe would have a small filter on the end.
#18 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 09 April 2021 - 11:45 AM
Hi,
Just an update for anyone still wanting to put a catchpot on there gearbox breather.
I have purchased this off ebay which seems pretty good for the money.
https://www.ebay.co....tm/143680694242
Plus some 15mm pipe
https://www.ebay.co....tm/114165963873
Then I'm using a makalu clamp at the gearbox end.
I currently have just a pipe leading up to the header tank, with no filter and I'm finding it's putting oil out, which ends up in my nearside rear wheel, which isn't good. The makalu fitting had never come off, which the old jubilee did.
Hopefully this should resolve it. You just need to move the inlets and blanking caps around on the catchpot to suit, they are all interchangeable.
AdamPosted ImagePosted ImagePosted Image
Sent from my SM-A526B using Tapatalk
#19 gaffer1986
gaffer1986
  • 4,408 posts
Posted 09 April 2021 - 12:21 PM
I had that catch can, like £100. I'm sure that's his much it cost 4 years or so ago.
Edited by gaffer1986, 09 April 2021 - 12:22 PM.
#20 swast4
swast4
  • 416 posts
Posted 09 April 2021 - 06:40 PM
Yeh when I looked they where pretty expensive for what they are but this comes in at under £20 Inc pipe, should do the job, just as well.
